my nextcloud is out of date. I use dockerized deployment with Mariadb (using docker-compose). In settings, it shows me that my docker is 19.0.0 and there is an update to 19.0.4 available. When I click on “Open updater”, I end up with blank screen (I get a 404 on request to /updater/).
Then I tried to update with occ:
docker exec -it -w /var/www/html -u www-data 6baebbcae145 php ./occ upgrade
Nextcloud is not installed - only a limited number of commands are available
Command "upgrade" is not defined.
It is interesting, because nextcloud is definitely installed - I see files, I sync with desktop app, I can login to web interface, I access apps.
How does nextcloud (command line) figure out if it is installed or not?
Nextcloud version (eg, 18.0.2): 19.0.0
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04.1 LTS, nextcloud is nextcloud:fpm docker image
Is this the first time you’ve seen this error? (Y/N): Yes
(these are unrelated and there are no logs that seem relevant)
{"reqId":"IkXQ2BZKIsF3hC2mPHFo","level":3,"time":"2020-10-16T10:29:03+00:00","remoteAddr":"172.18.0.1","user":"--","app":"PHP","method":"GET","url":"/index.php/apps/deck/api/v1.0/boards/3/stacks/11/cards/10?","message":"session_start(): A session had already been started - ignoring at /var/www/html/lib/private/Session/Internal.php#209","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.13.1","version":"19.0.0.12"}
{"reqId":"zeTBprNcXZXb2YssL15G","level":3,"time":"2020-10-16T10:29:03+00:00","remoteAddr":"172.18.0.1","user":"--","app":"PHP","method":"GET","url":"/index.php/apps/deck/api/v1.0/boards/5/stacks/16/cards/21?","message":"session_start(): A session had already been started - ignoring at /var/www/html/lib/private/Session/Internal.php#209","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.13.1","version":"19.0.0.12"}
{"reqId":"NsyIb9hUTntSvNvB6TZZ","level":3,"time":"2020-10-16T10:29:03+00:00","remoteAddr":"172.18.0.1","user":"--","app":"PHP","method":"GET","url":"/index.php/apps/deck/api/v1.0/boards/5/stacks/16/cards/24?","message":"session_start(): A session had already been started - ignoring at /var/www/html/lib/private/Session/Internal.php#209","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.13.1","version":"19.0.0.12"}
{"reqId":"ptPYbpH5zmDczAIeTVWC","level":3,"time":"2020-10-16T10:29:04+00:00","remoteAddr":"172.18.0.1","user":"--","app":"PHP","method":"GET","url":"/index.php/apps/deck/api/v1.0/boards/4/stacks/12/cards/12?","message":"session_start(): A session had already been started - ignoring at /var/www/html/lib/private/Session/Internal.php#209","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.13.1","version":"19.0.0.12"}
{"reqId":"7uG6PrjTRPLjwBa8SFbk","level":3,"time":"2020-10-16T10:29:04+00:00","remoteAddr":"172.18.0.1","user":"--","app":"PHP","method":"GET","url":"/index.php/apps/deck/api/v1.0/boards/4/stacks/12/cards/15?","message":"session_start(): A session had already been started - ignoring at /var/www/html/lib/private/Session/Internal.php#209","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.13.1","version":"19.0.0.12"}
{"reqId":"bqQJ9H1hivvbBOZn6I8y","level":3,"time":"2020-10-16T10:29:04+00:00","remoteAddr":"172.18.0.1","user":"--","app":"PHP","method":"GET","url":"/index.php/apps/deck/api/v1.0/boards/4/stacks/12/cards/39?","message":"session_start(): A session had already been started - ignoring at /var/www/html/lib/private/Session/Internal.php#209","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.13.1","version":"19.0.0.12"}
{"reqId":"iZ4H8P8HgwB7lVHKHvRU","level":3,"time":"2020-10-16T10:29:04+00:00","remoteAddr":"172.18.0.1","user":"--","app":"PHP","method":"GET","url":"/index.php/apps/deck/api/v1.0/boards/4/stacks/12/cards/58?","message":"session_start(): A session had already been started - ignoring at /var/www/html/lib/private/Session/Internal.php#209","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.13.1","version":"19.0.0.12"}
{"reqId":"4tt2ddft7GdKhJUdTtS0","level":3,"time":"2020-10-16T10:29:04+00:00","remoteAddr":"172.18.0.1","user":"--","app":"PHP","method":"GET","url":"/index.php/apps/deck/api/v1.0/boards/4/stacks/12/cards/14?","message":"session_start(): A session had already been started - ignoring at /var/www/html/lib/private/Session/Internal.php#209","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.13.1","version":"19.0.0.12"}
{"reqId":"XpXOroxsrRhktFf5bEvH","level":3,"time":"2020-10-16T10:29:04+00:00","remoteAddr":"172.18.0.1","user":"--","app":"PHP","method":"GET","url":"/index.php/apps/deck/api/v1.0/boards/4/stacks/12/cards/42?","message":"session_start(): A session had already been started - ignoring at /var/www/html/lib/private/Session/Internal.php#209","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.13.1","version":"19.0.0.12"}
{"reqId":"jzzkFJGXS6RTqgmnIoA9","level":3,"time":"2020-10-16T10:29:04+00:00","remoteAddr":"172.18.0.1","user":"--","app":"PHP","method":"GET","url":"/index.php/apps/deck/api/v1.0/boards/5/stacks/17/cards/23?","message":"session_start(): A session had already been started - ignoring at /var/www/html/lib/private/Session/Internal.php#209","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.13.1","version":"19.0.0.12"}
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'instanceid' => 'XXXXXXXXXXXX',
'passwordsalt' => 'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX',
'secret' => 'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX',
0 => 'nextcloud.XXXXXX.XX',
1 => 'nginx-server',
'version' => '19.0.0.12',
'overwrite.cli.url' => 'https://nextcloud.XXXXXX.XX',
'overwritehost' => 'nextcloud.XXXXXX.XX',
'dbname' => 'nextcloud',
'dbhost' => 'db',
'dbuser' => 'nextcloud',
'dbpassword' => 'XXXXXXXXXXXXX',
'onlyoffice' =>
'DocumentServerUrl' => '/ds-vpath/',
'DocumentServerInternalUrl' => 'http://onlyoffice-document-server/',
'StorageUrl' => 'http://nginx-server/',
'allow_local_remote_servers' => 'true',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'tls',
'mail_domain' => 'XXXXXX.XX',
'mail_smtpauth' => 1,
'mail_smtphost' => 'smtp.XXXXXXXX.XX',
'mail_smtpport' => '587',
'mail_smtpname' => 'XXXXXXXXX@XXXXXX.XX',
'mail_smtppassword' => 'XXXXXXXXXXXXXXXX',
'updater.secret' => '$2y$10$XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX',
172.22.0.2 - 16/Oct/2020:08:29:24 +0000 "GET /index.php" 200
172.22.0.2 - juraj 16/Oct/2020:08:35:02 +0000 "PROPFIND /remote.php" 302
172.22.0.2 - juraj 16/Oct/2020:08:43:13 +0000 "PROPFIND /remote.php" 302
172.22.0.2 - 16/Oct/2020:08:44:24 +0000 "GET /index.php" 200
172.22.0.2 - juraj 16/Oct/2020:08:51:20 +0000 "PROPFIND /remote.php" 302
172.22.0.2 - 16/Oct/2020:08:59:24 +0000 "GET /index.php" 200
172.22.0.2 - juraj 16/Oct/2020:08:59:30 +0000 "PROPFIND /remote.php" 302
172.22.0.2 - 16/Oct/2020:09:00:46 +0000 "GET /index.php" 200
172.22.0.2 - juraj 16/Oct/2020:09:07:37 +0000 "PROPFIND /remote.php" 302
172.22.0.2 - 16/Oct/2020:09:10:50 +0000 "GET /index.php" 200
172.22.0.2 - 16/Oct/2020:09:12:07 +0000 "GET /index.php" 200
172.22.0.2 - 16/Oct/2020:09:13:08 +0000 "GET /index.php" 200
172.22.0.2 - juraj 16/Oct/2020:09:15:38 +0000 "PROPFIND /remote.php" 302
172.22.0.2 - juraj 16/Oct/2020:09:23:45 +0000 "PROPFIND /remote.php" 302
172.22.0.2 - 16/Oct/2020:09:27:07 +0000 "GET /index.php" 200
172.22.0.2 - juraj 16/Oct/2020:09:31:50 +0000 "PROPFIND /remote.php" 302
172.22.0.2 - juraj 16/Oct/2020:09:39:51 +0000 "PROPFIND /remote.php" 302
172.22.0.2 - 16/Oct/2020:09:44:01 +0000 "GET /index.php" 200
172.22.0.2 - juraj 16/Oct/2020:09:48:01 +0000 "PROPFIND /remote.php" 302
[16-Oct-2020 09:49:48] NOTICE: fpm is running, pid 1
[16-Oct-2020 09:49:48] NOTICE: ready to handle connections
