Hello everybody, I have updated my nextcloud, which is running in a jail in truenas, to version 20.0.4 today, I then went into the browser and was asked again to do the update, which I did. the update was then aborted with an error and nextcloud went into maintenance mode I then brought nextcloud out of mode via config.php. Then the message came back with the update and it started all over again. Can I somehow downgrade Nextcloud? Here is the detailed error message
`## Update to 20.0.4
An error has occurred.
Detailed log messages
Prepare update
Log level set to “debug”
Maintenance mode switched on
Repair step: Repair MySQL collation
Repair information: All tables already have the correct collation -> nothing to do
Repair step: Repair SQLite autoincrement
Repair step: Copy data from accounts table when migrating from ownCloud
Repair step: Drop account terms table when migrating from ownCloud
The database schema is updated
Database updated
Look for an update for the accessibility app in the app store
App store checked for updates for the app “accessibility”
Check for an update for the “activity” app in the app store
App store checked for updates for the app “activity”
Check for an update for the bruteforcesettings app in the app store
App store checked for updates for the “bruteforcesettings” app
Look for an update for the “calendar” app in the app store
App store checked for updates for the “calendar” app
Look for an update for the “cloud_federation_api” app in the app store
App store checked for updates for the “cloud_federation_api” app
Check for an update to the “Comments” app in the App Store
App store checked for updates for the app “comments”
Check for an update to the “contactsinteraction” app in the app store
App store checked for updates for the “contactsinteraction” app
Check for an update to the dashboard app in the app store
App store checked for updates for the app “dashboard”
Check for an update for the “dav” app in the app store
App store checked for updates for app “dav”
Look for an update for the “end_to_end_encryption” app in the app store
App store checked for updates for the “end_to_end_encryption” app
Look for an update for the “federatedfilesharing” app in the app store
App store checked for updates for the “federatedfilesharing” app
Look for an update for the “federation” app in the app store
App store checked for updates for the “federation” app
Check for an update for the files app in the app store
App store checked for updates for the app “files”
Look for an update for the files_external app in the app store
App store checked for updates for the app “files_external”
Look for an update for the “files_pdfviewer” app in the app store
App store checked for updates for the app “files_pdfviewer”
Look for an update for the “files_rightclick” app in the app store
App store checked for updates for the app “files_rightclick”
Look for an update for the files_sharing app in the app store
App store checked for updates for the app “files_sharing”
Look for an update for the files_trashbin app in the app store
App store checked for updates for the app “files_trashbin”
Check for an update for the files_versions app in the app store
App store checked for updates for the app “files_versions”
Check for an update for the “files_videoplayer” app in the app store
App store checked for updates for the app “files_videoplayer”
Look for an update for the “firstrunwizard” app in the app store
App store checked for updates for the “firstrunwizard” app
Look for an update for the “logreader” app in the app store
App store checked for updates for the “logreader” app
Look for an update for the “lookup_server_connector” app in the app store
App store checked for updates for the app “lookup_server_connector”
Look for an update for the “nextcloud_announcements” app in the app store
App store checked for updates for the app “nextcloud_announcements”
Look for an update for the “notifications” app in the app store
App store checked for updates for the app “notifications”
Look for an update for the “oauth2” app in the app store
App store checked for updates for the “oauth2” app
Look for an update for the “onlyoffice” app in the app store
App store checked for updates for the “onlyoffice” app
Check for an update for the password_policy app in the app store
Mehr zu diesem Ausgangstext
Für weitere Übersetzungsinformationen ist ein Ausgangstext erforderlich
Feedback geben
Seitenleisten
can somebody help me?
best regards Leonard
