example
longer
example
here
Nextcloud version (eg, 12.0.2): 14.0.3
Operating system and version (eg, Ubuntu 17.04): Cent Os 7
PHP version (eg, 7.1): 7.2
I want to update my nextcloud with the web updater (stable channel).
After the click on “start update” I got this messages:
Current version is 14.0.3.
Update to Nextcloud 14.0.4 available. (channel: “stable”)
Following file will be downloaded automatically: https://download.nextcloud.com/server/releases/nextcloud-14.0.4.zip
Check for expected files
The following extra files have been found:
- ocm-provider
There are no entries in this time range
'instanceid' => '',
'passwordsalt' => '',
'secret' => '',
0 => '',
'datadirectory' => '',
'overwrite.cli.url' => '',
'version' => '14.0.3.0',
'dbname' => '',
'dbhost' => 'localhost',
'dbuser' => '',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'tls',
'mail_from_address' => '',
'mail_domain' => '',
'mail_smtpauth' => 1,
'mail_smtphost' => '',
'mail_smtpport' => '587',
'mail_smtpname' => '',
'mail_smtppassword' => '',
'theme' => '',
'loglevel' => 2,
'updater.secret' => '
