Nextcloud version: 13.0.4
Operating system and version: OpenSuse Leap 42.3
Apache or nginx version: Apache 2.4.23
PHP version: 7.0.7
If I enable theming in the apps section, then some time after a browser login one or more httpd processes will become CPU bound. The number of such processes increases over time.
If I disable theming, this does not happen.
- Enable all apps (except encryption in my case)
- Log in with browser, go to various apps (usually gallery and files is sufficient).
- Maybe login/logout and repeat if problem has not occurred yet.
No errors.
'instanceid' => '<stuff>',
'passwordsalt' => '<stuff>',
'secret' => '<stuff>/qAm+tUy1M4mfUwX5aF',
0 => '<stuff>',
1 => <stuff>',
5 => '<stuff>',
'datadirectory' => '<stuff>',
'overwrite.cli.url' => '<stuff>',
'dbtype' => 'sqlite3',
'version' => '13.0.4.0',
'logtimezone' => 'UTC',
'mail_smtpmode' => 'smtp',
'mail_from_address' => '<stuff>',
'mail_domain' => '<stuff>',
'mail_smtphost' => '<stuff>',
'theme' => '',
'loglevel' => 1,
'trashbin_retention_obligation' => 'auto',
'updatechecker' => false,
'updater.secret' => '<stuff>',
'redis' =>
'host' => 'localhost',
'port' => 6379,
'ldapIgnoreNamingRules' => false,
'ldapProviderFactory' => '\\OCA\\User_LDAP\\LDAPProviderFactory',
These lines repeated every few seconds (same as always):
==> /var/log/apache2/ssl_request_log <==
[21/Jun/2018:13:08:13 +1000] x.y.z.t TLSv1.2 “PROPFIND /remote.php/dav/files// HTTP/1.1” 364 “-” “Mozilla/5.0 (Windows) mirall/2.4.1 (build 9270)”
==> /var/log/apache2/access_log <==
<x.y.z.t> - [21/Jun/2018:13:08:13 +1000] “GET /ocs/v2.php/apps/notifications/api/v1/notifications?format=json HTTP/1.1” 200 74
