example
longer
example
here
Nextcloud version (eg, 20.0.5): 24.0.6
Operating system and version (eg, Ubuntu 20.04): Ubuntu Server 22.04
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.52 (Ubuntu)
PHP version (eg, 7.4): PHP 8.1.2
Another user sharing his calendar readonly to me, has a task. When synchronizing the calendars (including tasks) via davx to my phone, I get “Synchronization error: HTTP 404 Not found”.
- User shares calendar including tasks readonly
- I connect to all calendars via DavX on my mobile device
- After some time I get theses errors shown
PASTE HERE
Nothing in the logs rearding this problem
I’m not shure where to post this, in nextcloud or somewhere for DavX. I haven’t found any support board or possibility to report a Bug for DavX, so I try it here.
I can just Hide all synchronization errors on my Android device for DavX - but this shouldn’t be the solution.
Thanks for help. I’m sure this information is not enough. Thanks for any help and let me know what information I need to deliver.
