Problem with shared link expiration
    • 30.0.8
    • debian 12
    • nginx
    • caddy
    • 8.2
    • yes
    • can't say, just realized
    • docker, with php-fpm
    • cloudflare
When i create a share with expiry, then it’s immediately deleted, when i call the link or i want to view the share-information again. Somehow nextcloud decides to delete it immediately.
the db entry is there initially
nextcloud=# select * from oc_share where expiration is not null order by id desc limit 10;
  id   | share_type | share_with | password |  uid_owner  | uid_initiator | parent | item_type | item_source | item_target | file_source |  file_target   | permissions |   stime    | accepted |       expiration       |      token      | mail_send | share_name | password_by_talk | note | hide_download | label | attributes | password_expiration_time
 12010 |          3 |            |          | *** | ****   |        | file      | 46140       |             |       46140 | /thd-todos.txt |           1 | 1742545689 |        0 | 2025-03-24 23:00:00+00 | wHbpCQCBFcTc56C |         0 |            | f                |      |             0 |       |            |
but even though it’s not expired, it’s gone right when trying to retrieve these files.
It needs to do have to something with the installed apps or the configuration somehwere, but I don’t know how I could debug this. On other instances the expiry works fine.
Would really appreciate it if somebody could help me debugging this, where this comes from.
  1. create a share with expiry
  2. call it
  3. it’s gone
not much what i could share here to this problem, logs are very spammy, when setting it to debug level. otherwise no specific error.
{"reqId":"rdIgWDB97bcCC6rbT32d","level":1,"time":"2025-03-21T08:45:50+00:00","remoteAddr":"172.71.164.231","user":"--","app":"core","method":"GET","url":"/s/bjN9XDXT4WQ3wD5","message":"Bruteforce attempt from \"172.71.164.231\" detected for action \"ShareController::showShare\".","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:136.0) Gecko/20100101 Firefox/136.0","version":"30.0.8.1","data":{"app":"core"}}
        "htaccess.RewriteBase": "\/",
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "redis": {
            "port": 6379
            "localhost",
            "wir.treibhausdonaufeld.at"
        "dbtype": "pgsql",
        "version": "30.0.8.1",
        "overwrite.cli.url": "https:\/\/wir.treibhausdonaufeld.at",
        "dbport": "",
        "overwritehost": "wir.treibhausdonaufeld.at",
        "overwriteprotocol": "https",
        "overwritewebroot": "",
        "skeletondirectory": "",
        "mail_sendmailmode": "smtp",
        "mail_smtpmode": "smtp",
        "mail_smtpsecure": "tls",
        "mail_smtpauthtype": "LOGIN",
        "mail_smtpauth": 1,
        "mail_smtpport": "587",
        "filelocking.enabled": true,
        "loglevel": 2,
        "default_phone_region": "AT",
        "app_install_overwrite": [
            "files_texteditor",
            "deck"
        "maintenance_window_start": 1
  - activity: 3.0.0
  - admin_audit: 1.20.0
  - app_api: 4.0.6
  - bruteforcesettings: 3.0.0
  - calendar: 5.2.0
  - circles: 30.0.0
  - collectives: 2.16.1
  - comments: 1.20.1
  - contacts: 7.0.4
  - contactsinteraction: 1.11.0
  - dashboard: 7.10.0
  - dav: 1.31.1
  - deck: 1.14.4
  - drawio: 3.0.3
  - external: 5.5.2
  - federation: 1.20.0
  - files: 2.2.0
  - files_downloadlimit: 3.0.0
  - files_external: 1.22.0
  - files_fulltextsearch: 31.0.0
  - files_pdfviewer: 3.0.0
  - files_reminders: 1.3.0
  - files_sharing: 1.22.0
  - files_trashbin: 1.20.1
  - files_versions: 1.23.0
  - firstrunwizard: 3.0.0
  - forms: 5.0.4
  - fulltextsearch: 30.0.1
  - fulltextsearch_elasticsearch: 30.0.1
  - impersonate: 1.17.1
  - logreader: 3.0.0
  - mail: 4.3.1
  - notifications: 3.0.0
  - oauth2: 1.18.1
  - onlyoffice: 9.7.0
  - password_policy: 2.0.0
  - polls: 7.4.1
  - privacy: 2.0.0
  - provisioning_api: 1.20.0
  - settings: 1.13.0
  - suspicious_login: 8.0.0
  - systemtags: 1.20.0
  - terms_of_service: 4.3.0
  - text: 4.1.0
  - theming: 2.6.0
  - theming_customcss: 1.18.0
  - thesearchpage: 1.2.10
  - twofactor_totp: 12.0.0-dev
  - updatenotification: 1.20.0
  - viewer: 3.0.0
  - welcome: 1.2.1
  - workflowengine: 2.12.0
I would assume that expiration of links and other background activities are executed by a background task. Check if the cron job is correctly set-up and executed on a regular base.
hi, thanks for your reply - but it’s not a background-job problem, it mainly happens when i try to open the shared link, then it’s immediately expired. also when i refresh the share details of that file or folder
