Problem with notify_push and dyndns (dynamic IP)
Intro / Why am I here?
First of all, thank you very much for your help.
The following warning message was displayed in the Administration settings / Overview under Security & Setup warnings: “Client-Push is not installed. This may cause performance issues when using desktop clients”
This prompted me to install and activate notify_push.
The most annoying and as yet unsolved problem is the configuration of “trusted_proxies.” IP addresses must be entered there, which is somewhat difficult with dynamic IPs.
Questions
  • Without the IP address in config.php, you get an error message:
    occ notify_push:self-test
If you're having issues getting the trusted proxy setup working, you can try bypassing any existing reverse proxy
in your setup by setting the `NEXTCLOUD_URL` environment variable to point directly to the internal Nextcloud webserver url
(You will still need the ip address of the push server added as trusted proxy)
Again: You will still need the ip address of the push server added as trusted proxy
My questions:
  1. Who do you have to ask to enable notify_push to work via DynDNS? Or does it already do that and I haven’t found any information about it?
  2. Does the following addition to config.php make sense? Why?
    ‘forwarded_for_headers’ => [‘HTTP_X_FORWARDED_FOR’],
  3. notify_push does not work as expected, even though:
    ✓ redis is configured
    ✓ push server is receiving redis messages
    ✓ push server can load mount info from database
    ✓ push server can connect to the Nextcloud server
    ✓ push server is a trusted proxy
    ✓ push server is running the same version as the app
    But my test: Open Nextcloud in two browsers, create a file in one → no change in the second tab
    But in the Firefox developer tools, you can see messages about the service arriving in the Network → WS tab.
    How can I check whether notify_push is working as it should?
  4. If you enter the currently valid IP address in config.php and call /index.php/settings/admin/overview from the same network, you get the following message in the Administration settings / Overview under Security & Setup warnings:
    *”The configuration of the reverse proxy header is incorrect, or you are accessing Nextcloud via a trusted proxy. Otherwise, this poses a security risk and may allow an attacker to spoof their IP address so that it is visible to Nextcloud.” (Message translated into English)
    I guess that’s okay. Am I right?
    • 32.0.1
    • Arch Linux
    • Apache 2.4.65
    • Apache mod_proxy
    • 8.2.29
    • Yes
    • with installation and configuration
    • Arch Packages
    • replace me
The notify_push app does not work with DynDNS.
What I had to do on Arch Linux to install notify_push:
(If redis (valkey) or other components are missing, you naturally have more work to do, but much of it is well described in the Arch wiki.)
pacman -S nextcloud-app-notify_push
systemctl edit nextcloud-app-notify_push.service
[Unit]
After = valkey.service mariadb.service php-fpm-1egacy.service httpd.service
[Service]
Environment = NEXTCLOUD_URL=https://<my-dyndns-address>/
sudo systemctl enable --now nextcloud-app-notify_push.service
edit /etc/httpd/conf/extra/nextcloud.conf
<VirtualHost *:443>
    # Tested with and without RequestHeader
    RequestHeader set "X-Forwarded-Proto"expr=%{REQUEST_SCHEME}
    ProxyRequests Off
    ProxyPreserveHost On
    ProxyPass /push/ws/ ws://127.0.0.1:7867/ws/
    ProxyPass /push/ ws://127.0.0.1:7867/
    ProxyPassReverse /push/ ws://127.0.0.1:7867/
</VirtualHost>
systemctl restart httpd.service
occ app:enable notify_push
occ notify_push:setup (=> error messages)
occ maintenance:mode --on
edit /etc/webapps/nextcloud/config/config.php
  'trusted_proxies' =>
    0 => '<my-dynamic-ip>',
	1 => '127.0.0.1',
    2 => '::1',
occ maintenance:mode --off
If log entries are needed to solve my problem, please let me know.
The most important question is: how do you configure “trusted_proxies” with a dynamic IP address? Because the last time I checked, you could only enter a fixed address.
Now almost three months have passed, an answer to the question is important to me, and writing the post took time.
Therefore, I ask for your understanding that I am responding myself to prevent the topic from closing on its own.
I don’t think it should be necessary to enter the external IP address of your internet connection there. In most cases, I’d say 127.0.0.1 should be enough, provided that the Apache server through which you are proxying the requests is running on the same server as Nextcloud. In some situations you might also want to add the local IP address of the server, in addition. Of course, if you are using a reverse proxy in front of your Apache/Nextcloud server, you will also need to add that IP address.
Not sure if it is supposed to work like that. I tested it with my main instance (manual LAMP installation) and AIO, and in neither case did a new file automatically appear in the other tab or browser without refreshing the page.
There’s a test tool you can download: https://github.com/nextcloud/notify_push#test-client
Download the respective binary for your OS, create an app apssword in Nextcloud, and then execute it:
./test_client-x86_64-unknown-linux-musl https://cloud.yourdomain.tld username apppassword
Then, in Nextcloud, create a file, for example. If notify_push is working, you should receive a message like this:
[2026-02-04 08:03:28.171634 +01:00] INFO [test_client] test_client/src/main.rs:67: Received file update notification notify_file_id [2,4649207]
