On my Raspberry Pi i got NextCloudPi working. However, after installing some add-ons like OnlyOffice and other suddnely I could not access the web UI. Now I get this message:
This page isn’t working
192.168.1.104 is currently unable to handle this request.
HTTP ERROR 500
Although, I am able to access the NextCloudPi Panel (settings: eg Backup, lets Encrypt etc).
so, I tried to re-install NextCloudPi and in the Terminal it aborts at this stage:
2019-01-20 1:27:49 1996152832 [Note] mysqld (mysqld 10.1.37-`MariaDB-0+deb9u1) starting as process 27197 ...`
2019-01-20 1:27:49 1996152832 [Warning] Can't create test file /var/lib/mysql/raspberrypi.lower-test
mysqld: Can't change dir to '/var/lib/mysql/' (Errcode: 2 "No such file or directory")
2019-01-20 1:27:49 1996152832 [ERROR] Aborting
I’m just wondering how I can fix this issue and get NextCloud working again. I have no idea why an Add-on would do this to an installation.
Do yu mean a complete reinstallation of NextCloud or mariadb? And (here’s the noob question) how would I go bout doing that? Thank you very much for the reply, by the way.
pi@raspberrypi:~ $ sudo systemctl status mariadb
â—Ź mariadb.service - MariaDB 10.1.37 database server
Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor preset:
Drop-In: /etc/systemd/system/mariadb.service.d
└─ncp-delay-automount.conf
Active: activating (start-pre) since Sun 2019-01-20 03:34:05 AEDT; 6s ago
Docs: man:mysqld(8)
https://mariadb.com/kb/en/library/systemd/
Process: 11949 ExecStart=/usr/sbin/mysqld $MYSQLD_OPTS $_WSREP_NEW_CLUSTER $_W
Process: 12006 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VA
Process: 12001 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_STAR
Process: 11997 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/r
Main PID: 11949 (code=exited, status=1/FAILURE); Control PID: 12159 (sleep)
CGroup: /system.slice/mariadb.service
└─control
└─12159 /bin/sleep 20
Jan 20 03:34:05 raspberrypi systemd[1]: Starting MariaDB 10.1.37 database server
lines 1-17/17 (END)
sudo ls -l /var/lib/mysql
pi@raspberrypi:~ $ sudo ls -l /var/lib/mysql
ls: cannot access '/var/lib/mysql': No such file or directory
sudo dpkg -l | grep mariadb
pi@raspberrypi:~ $ sudo dpkg -l | grep mariadb
ii mariadb-client-10.1 10.1.37-0+deb9u1 armhf MariaDB database client binaries
ii mariadb-client-core-10.1 10.1.37-0+deb9u1 armhf MariaDB database core client binaries
ii mariadb-common 10.1.37-0+deb9u1 all MariaDB common metapackage
ii mariadb-server 10.1.37-0+deb9u1 all MariaDB database server (metapackage depending on the latest version)
ii mariadb-server-10.1 10.1.37-0+deb9u1 armhf MariaDB database server binaries
ii mariadb-server-core-10.1 10.1.37-0+deb9u1 armhf MariaDB database core server files
Maybe I could just do a complete reinstallation of Raspbian and NextCloudPi?
pi@raspberrypi:~ $ sudo systemctl restart mariadb
Job for mariadb.service failed because the control process exited with error code.
See "systemctl status mariadb.service" and "journalctl -xe" for details.
Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Sun 2019-01-20 05:01:10 AEDT; 2s ago
Docs: man:mysqld(8)
Process: 546 ExecStart=/usr/sbin/mysqld $MYSQLD_OPTS $_WSREP_NEW_CLUSTER $_WSREP_START_POSITION (code=exited, status=1/FAILURE)
Process: 474 ExecStartPre=/bin/sleep 20 (code=exited, status=0/SUCCESS)
Process: 32763 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= || VAR=`/usr/bin/galera_recovery`; [ $? -eq 0 ] && systemctl s
Process: 32758 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Process: 32753 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, status=0/SUCCESS)
Main PID: 546 (code=exited, status=1/FAILURE)
Status: "MariaDB server is down"
Jan 20 05:01:10 raspberrypi systemd[1]: Failed to start MariaDB 10.1.37 database server.
Jan 20 05:01:10 raspberrypi systemd[1]: mariadb.service: Unit entered failed state.
Jan 20 05:01:10 raspberrypi systemd[1]: mariadb.service: Failed with result 'exit-code'.
journalctl -xe
Jan 20 04:49:40 raspberrypi systemd[1]: nextcloud-domain.service: Main process e
Jan 20 04:49:40 raspberrypi systemd[1]: nextcloud-domain.service: Unit entered f
Jan 20 04:49:40 raspberrypi systemd[1]: nextcloud-domain.service: Failed with re
Jan 20 04:49:44 raspberrypi systemd[1]: mariadb.service: Service hold-off time o
Jan 20 04:49:44 raspberrypi systemd[1]: Stopped MariaDB 10.1.37 database server.
-- Subject: Unit mariadb.service has finished shutting down
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- Unit mariadb.service has finished shutting down.
Jan 20 04:49:44 raspberrypi systemd[1]: Starting MariaDB 10.1.37 database server
-- Subject: Unit mariadb.service has begun start-up
-- Unit mariadb.service has begun starting up.
Jan 20 04:49:45 raspberrypi systemd[1]: nextcloud-domain.service: Service hold-o
Jan 20 04:49:45 raspberrypi systemd[1]: Stopped Register Current IP as Nextcloud
-- Subject: Unit nextcloud-domain.service has finished shutting down
-- Unit nextcloud-domain.service has finished shutting down.
lines 1384-1406/1406 (END)
Thank you for your support. I am only learning still.
I would give it a try, but I would need access to your machine. Do your have some kind of VPN, or TeamViewer installed? What OS is running on your machine?
