Hi, I’m trying to create personal nextcloud instance via docker-compose, sadly when I’m trying docker-compose up
nothing happens.
Here is my docker-compose.yml
version: '3.2'
services:
proxy:
image: jwilder/nginx-proxy:alpine
labels:
- "com.github.jrcs.letsencrypt_nginx_proxy_companion.nginx_proxy=true"
container_name: nextcloud-proxy
networks:
- nextcloud_network
ports:
- 80:80
- 443:443
volumes:
- ./proxy/conf.d:/etc/nginx/conf.d:rw
- ./proxy/vhost.d:/etc/nginx/vhost.d:rw
- ./proxy/html:/usr/share/nginx/html:rw
- ./proxy/certs:/etc/nginx/certs:ro
- /etc/localtime:/etc/localtime:ro
- /var/run/docker.sock:/tmp/docker.sock:ro
restart: unless-stopped
letsencrypt:
image: jrcs/letsencrypt-nginx-proxy-companion
container_name: nextcloud-letsencrypt
depends_on:
- proxy
networks:
- nextcloud_network
volumes:
- ./proxy/certs:/etc/nginx/certs:rw
db:
image: postgres
container_name: nextcloud-postgres
restart: always
volumes:
- db:/var/lib/postgresql/data
networks:
- nextcloud_network
environment:
- POSTGRES_DB_FILE=/run/secrets/postgres_db
- POSTGRES_USER_FILE=/run/secrets/postgres_user
- POSTGRES_PASSWORD_FILE=/run/secrets/postgres_password
secrets:
- postgres_db
- postgres_password
- postgres_user
app:
image: nextcloud
container_name: nextcloud-app
networks:
- nextcloud_network
restart: always
ports:
- 8080:80
volumes:
- nextcloud:/var/www/html
environment:
- POSTGRES_HOST=db
- NEXTCLOUD_ADMIN_PASSWORD_FILE=/run/secrets/nextcloud_admin_password
- NEXTCLOUD_ADMIN_USER_FILE=/run/secrets/nextcloud_admin_user
depends_on:
- letsencrypt
- proxy
- db
environment:
- VIRTUAL_HOST=codenotes.dev
- LETSENCRYPT_HOST=codenotes.dev
- LETSENCRYPT_EMAIL=andrzej.zahorski@gmail.com
secrets:
- nextcloud_admin_password
- nextcloud_admin_user
- postgres_db
- postgres_password
- postgres_user
volumes:
db:
nextcloud:
secrets:
nextcloud_admin_password:
file: ./nextcloud_admin_password.txt # put admin password to this file
nextcloud_admin_user:
file: ./nextcloud_admin_user.txt # put admin username to this file
postgres_db:
file: ./postgres_db.txt # put postgresql db name to this file
postgres_password:
file: ./postgres_password.txt # put postgresql password to this file
postgres_user:
file: ./postgres_user.txt # put postgresql username to this file
networks:
nextcloud_network:
passwords are created via openssl rand -base64 12
and user names are made by me.
What should I do to get this running?
