I got a problem when I’am trying to connect OnlyOffice Desktop Editor (Ubuntu 18.04) to my Nextcloud, I got an timeout and this error message :
ERROR:cert_verify_proc_nss.cc(921)] CERT_PKIXVerifyCert for nextcloud.domain.name failed err=-8179
I got two VM, one for nextcloud and one for OnlyOffice, The installation of the app OnlyOffice on the Nextcloud server worked well. And when I am using Onlyoffice from a web browser through nextcloud server is worked well too.
The both server got a HTTPS configuration with an CA authority self signed. I added this CA in /usr/local/share/ca-certificates/
For try, I added the CA on the client VM (Ubuntu 18.04) but that not resolve the problem…
I Modified the config.php from Nextcloud for connect to OnlyOffice :
'onlyoffice' => array ( 'verify_peer_off' => TRUE, ),
The both servers works on Ubuntu 18.04, and I follow Install instructions from the official site.
All DNS records are update from /etc/hosts for the 3 VM.
Here my configurations files :
Nextcloud config.php
'instanceid' => 'string',
'passwordsalt' => '+string',
'secret' => '+string',
0 => 'nextcloud.domain.name',
1 => 'lan network*',
'datadirectory' => '/usr/share/nginx/nextcloud-data',
'version' => '18.0.1.3',
'overwrite.cli.url' => 'https://nextcloud.domain.name',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextclouduser',
'dbpassword' => 'cloud',
'ldapIgnoreNamingRules' => false,
"log_type" => "file",
"logfile" => "/var/log/nextcloud.log",
"loglevel" => "1",
"logdateformat" => "F d, Y H:i:s",
Nextcloud NGINX :
server {
listen IP_LAN_NEXTCLOUD_SERVER:443 ssl http2;
server_name nextcloud.domain.name;
#ssl
ssl_certificate /etc/nginx/ssl/Nextcloud.crt;
ssl_certificate_key /etc/nginx/ssl/Nextcloud.key;
ssl_protocols TLSv1.2 TLSv1.1 TLSv1;
add_header X-Robots-Tag none;
add_header Referrer-Policy no-referrer;
#I found this header is needed on Ubuntu, but not on Arch Linux.
add_header X-Frame-Options "SAMEORIGIN";
root /usr/share/nginx/nextcloud/;
access_log /var/log/nginx/nextcloud.access;
error_log /var/log/nginx/nextcloud.error;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
#rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
#rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json
# last;
location ~ /.well-known/acme-challenge {
allow all;
# set max upload size
client_max_body_size 1024M;
fastcgi_buffers 64 4K;
# Disable gzip to avoid the removal of the ETag header
gzip off;
#pagespeed off;
error_page 403 /core/templates/403.php;
error_page 404 /core/templates/404.php;
location / {
rewrite ^ /index.php$uri;
deny all;
deny all;
location ~ ^/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+|core/templates/40[34])\.php(?:$|/) {
include fastcgi_params;
fastcgi_split_path_info ^(.+\.php)(/.*)$;
fastcgi_pass unix:/run/php/php7.2-fpm.sock;
fastcgi_intercept_errors on;
location ~ ^/(?:updater|ocs-provider)(?:$|/) {
try_files $uri/ =404;
index index.php;
# Adding the cache control header for js and css files
location ~* \.(?:css|js)$ {
try_files $uri /index.php$uri$is_args$args;
add_header Cache-Control "public, max-age=7200";
# Add headers to serve security related headers (It is intended to
# have those duplicated to the ones above)
access_log off;
location ~* \.(?:svg|gif|png|html|ttf|woff|ico|jpg|jpeg)$ {
# Optional: Don't log access to other assets
access_log off;
OnlyOffice local.json :
"services": {
"CoAuthoring": {
"sql": {
"dbHost": "localhost",
"dbName": "onlyoffice",
"dbUser": "onlyoffice",
"dbPass": "onlyoffice"
"redis": {
"host": "localhost"
"token": {
"enable": {
"request": {
"inbox": true,
"outbox": true
"browser": true
"inbox": {
"header": "Authorization"
"outbox": {
"secret": {
"inbox": {
"string": "topsecrettoken"
"outbox": {
"session": {
"rabbitmq": {
"url": "amqp://guest:guest@localhost"
OnlyOffice NGINX :
include /etc/nginx/includes/http-common.conf;
server {
listen IP_LAN_ONLYOFFICE_SERVER:443 ssl http2;
server_tokens off;
server_name onlyoffice.domain.name;
#ssl
ssl_certificate /etc/nginx/ssl/OnlyOffice.crt;
ssl_certificate_key /etc/nginx/ssl/OnlyOffice.key;
include /etc/nginx/includes/ds-*.conf;
EDIT : Now when I’ am using nextcloud and onlyoffice accross web browser and from an another machine I got the follow error message :
OnlyOffice is unavailable. Please contact your administrator.
Anyone could help me plz ?
Thanks for reading,
