Hello
I see that in polish version of translation there’s probably an error with linking to the website - this occurs while MacOs Desktop client is updated - I suppose this is a typo in code. See screenshot.
Regards
PS
Hello
Regards
PS
The Polish translation is correct. I don’t see any error. The problem may be in the application code itself.
For version 3.1.2 the message is changed to “New Nextcloud x.x is available. Please click here to download the update.” Also the problem may already be fixed.
@rakekniven Or maybe notifications do not support this code?
Hello
I’ve updated the client. I’ll let you know if the problem occur.
Thanks for your support.
PS
Transifex looks good to me as well. https://www.transifex.com/nextcloud/nextcloud/translate/#pl/client/184351186?q=text%3Aupdate
I am on 3.1.2 already on all clients and therefor cannot check with other languages
Hello polish group,
same thing happened using german client.
See:
Would you mind filing an issue at Issues · nextcloud/desktop · GitHub ?
Did a quick search and could not find any related issue.
Maybe you?
Thank you.
Cheers.
