- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
32.0.5.0
Alpine Linux Edge
Nginx1.28.0
Nginx 1.28.0
- PHP version (e.g, 8.3):
8.4
Yes
After installation wizard
Archive
No
After runing the GUI install (From the url i want to use to access the server “domain.tld/cloud”) i get redirected to https://cloud. looking into config/config.php i see that overwrite.cli.url = https:///cloud and trusted_domains is empty, when entering from domain.tld/cloud/login it works, changing trusted_domains or overwrite.cli.url ends up in untrusted domain error
empty
when entering with domain.tld/cloud
cloud/ 302
nothing in any log
"overwrite.cli.url": "https:\/\/\/cloud\/",
"dbtype": "pgsql",
"version": "32.0.5.0",
"installed": true
- activity: 5.0.0-dev.0
- app_api: 32.0.0
- circles: 32.0.0
- comments: 1.22.0
- contactsinteraction: 1.13.1
- dashboard: 7.12.0
- dav: 1.34.2
- federation: 1.22.0
- files: 2.4.0
- files_reminders: 1.5.0
- files_sharing: 1.24.1
- files_trashbin: 1.22.0
- files_versions: 1.25.0
- firstrunwizard: 5.0.0-dev.0
- logreader: 5.0.0-dev.0
- notifications: 5.0.0-dev.0
- oauth2: 1.20.0
- photos: 5.0.0-dev.1
- privacy: 4.0.0-dev.0
- profile: 1.1.0
- provisioning_api: 1.22.0
- serverinfo: 4.0.0-dev.0
- settings: 1.15.1
- sharebymail: 1.22.0
- support: 4.0.0-dev.0
- survey_client: 4.0.0-dev.0
- systemtags: 1.22.0
- text: 6.0.1
- theming: 2.7.0
- updatenotification: 1.22.0
- user_status: 1.12.0
- viewer: 5.0.0-dev.0
- weather_status: 1.12.0
- webhook_listeners: 1.3.0
- workflowengine: 2.14.0
Disabled: - admin_audit: 1.22.0
- encryption: 2.20.0
- files_external: 1.24.1
- twofactor_totp: 14.0.0
- user_ldap: 1.23.0
