Hello!
We are try to test your solution.
But can’t install server.
firstly i try to use ready to use OVA file but when i import it to vmware vsphere it show the error with MD5 sum.
After that i try to install it on debian 11 with docker using this documentation: GitHub - nextcloud/all-in-one: Nextcloud AIO stands for Nextcloud All In One and provides easy deployment and maintenance with most features included in this one Nextcloud instance..
after installation i went to 8080 port
After some steps i see what services:
- Apache
- nextcloud
- clamav
- fulltext search
not started, there are screen shoot: AIO
On the Logs:
Apache errors:
Waiting for Nextcloud to start…
nc: getaddrinfo for host “nextcloud-aio-nextcloud” port 9000: Name or service not known
nextcloud errors:
waiting for clamav to become available…
Clamav error:
or clamd not found yet, retrying (35/1800) …Database test passed.
daily.cld updated (version: 26749, sigs: 2013718, f-level: 90, builder: raynman)
main.cvd database is up-to-date (version: 62, sigs: 6647427, f-level: 90, builder: sigmgr)
bytecode.cvd database is up-to-date (version: 333, sigs: 92, f-level: 63, builder: awillia2)
WARNING: Clamd was NOT notified: Can’t connect to clamd through /tmp/clamd.sock: No such file or directory
or clamd not found yet, retrying (36/1800) …
or clamd not found yet, retrying (37/1800) …
or clamd not found yet, retrying (38/1800) …
or clamd not found yet, retrying (39/1800) …
or clamd not found yet, retrying (40/1800) …
or clamd not found yet, retrying (41/1800) …
or clamd not found yet, retrying (42/1800) …
or clamd not found yet, retrying (43/1800) …
Fulltext search:
type": “server”, “timestamp”: “2022-12-14T04:28:29,918Z”, “level”: “INFO”, “component”: “o.e.g.GatewayService”, “cluster.name”: “docker-cluster”, “node.name”: “c99f2a183c80”, “message”: “recovered [3] indices into cluster_state”, “cluster.uuid”: “NkExJ_5qRcSsazSpMv6rzQ”, “node.id”: “QLFhT197R8KRCibPK7mtUg” }
{“type”: “server”, “timestamp”: “2022-12-14T04:28:30,601Z”, “level”: “ERROR”, “component”: “o.e.i.g.GeoIpDownloader”, “cluster.name”: “docker-cluster”, “node.name”: “c99f2a183c80”, “message”: “exception during geoip databases update”, “cluster.uuid”: “NkExJ_5qRcSsazSpMv6rzQ”, “node.id”: “QLFhT197R8KRCibPK7mtUg” ,
“stacktrace”: [“org.elasticsearch.ElasticsearchException: not all primary shards of [.geoip_databases] index are active”,
“at org.elasticsearch.ingest.geoip.GeoIpDownloader.updateDatabases(GeoIpDownloader.java:137) ~[ingest-geoip-7.17.7.jar:7.17.7]”,
“at org.elasticsearch.ingest.geoip.GeoIpDownloader.runDownloader(GeoIpDownloader.java:284) [ingest-geoip-7.17.7.jar:7.17.7]”,
“at org.elasticsearch.ingest.geoip.GeoIpDownloaderTaskExecutor.nodeOperation(GeoIpDownloaderTaskExecutor.java:100) [ingest-geoip-7.17.7.jar:7.17.7]”,
“at org.elasticsearch.ingest.geoip.GeoIpDownloaderTaskExecutor.nodeOperation(GeoIpDownloaderTaskExecutor.java:46) [ingest-geoip-7.17.7.jar:7.17.7]”,
“at org.elasticsearch.persistent.NodePersistentTasksExecutor$1.doRun(NodePersistentTasksExecutor.java:42) [elasticsearch-7.17.7.jar:7.17.7]”,
“at org.elasticsearch.common.util.concurrent.ThreadContext$ContextPreservingAbstractRunnable.doRun(ThreadContext.java:777) [elasticsearch-7.17.7.jar:7.17.7]”,
“at org.elasticsearch.common.util.concurrent.AbstractRunnable.run(AbstractRunnable.java:26) [elasticsearch-7.17.7.jar:7.17.7]”,
“at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1144) [?:?]”,
“at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:642) [?:?]”,
“at java.lang.Thread.run(Thread.java:1589) [?:?]”] }
{“type”: “server”, “timestamp”: “2022-12-14T04:28:30,804Z”, “level”: “INFO”, “component”: “o.e.c.r.a.AllocationService”, “cluster.name”: “docker-cluster”, “node.name”: “c99f2a183c80”, “message”: “Cluster health status changed from [RED] to [GREEN] (reason: [shards started [[.geoip_databases][0]]]).”, “cluster.uuid”: “NkExJ_5qRcSsazSpMv6rzQ”, “node.id”: “QLFhT197R8KRCibPK7mtUg” }
{“type”: “server”, “timestamp”: “2022-12-14T04:28:30,835Z”, “level”: “INFO”, “component”: “o.e.i.g.DatabaseNodeService”, “cluster.name”: “docker-cluster”, “node.name”: “c99f2a183c80”, “message”: “retrieve geoip database [GeoLite2-Country.mmdb] from [.geoip_databases] to [/tmp/elasticsearch-207938627936206560/geoip-databases/QLFhT197R8KRCibPK7mtUg/GeoLite2-Country.mmdb.tmp.gz]”, “cluster.uuid”: “NkExJ_5qRcSsazSpMv6rzQ”, “node.id”: “QLFhT197R8KRCibPK7mtUg” }
{“type”: “server”, “timestamp”: “2022-12-14T04:28:30,846Z”, “level”: “INFO”, “component”: “o.e.i.g.DatabaseNodeService”, “cluster.name”: “docker-cluster”, “node.name”: “c99f2a183c80”, “message”: “retrieve geoip database [GeoLite2-City.mmdb] from [.geoip_databases] to [/tmp/elasticsearch-207938627936206560/geoip-databases/QLFhT197R8KRCibPK7mtUg/GeoLite2-City.mmdb.tmp.gz]”, “cluster.uuid”: “NkExJ_5qRcSsazSpMv6rzQ”, “node.id”: “QLFhT197R8KRCibPK7mtUg” }
{“type”: “server”, “timestamp”: “2022-12-14T04:28:30,847Z”, “level”: “INFO”, “component”: “o.e.i.g.DatabaseNodeService”, “cluster.name”: “docker-cluster”, “node.name”: “c99f2a183c80”, “message”: “retrieve geoip database [GeoLite2-ASN.mmdb] from [.geoip_databases] to [/tmp/elasticsearch-207938627936206560/geoip-databases/QLFhT197R8KRCibPK7mtUg/GeoLite2-ASN.mmdb.tmp.gz]”, “cluster.uuid”: “NkExJ_5qRcSsazSpMv6rzQ”, “node.id”: “QLFhT197R8KRCibPK7mtUg” }
{“type”: “server”, “timestamp”: “2022-12-14T04:28:31,703Z”, “level”: “INFO”, “component”: “o.e.i.g.DatabaseNodeService”, “cluster.name”: “docker-cluster”, “node.name”: “c99f2a183c80”, “message”: “successfully reloaded changed geoip database file [/tmp/elasticsearch-207938627936206560/geoip-databases/QLFhT197R8KRCibPK7mtUg/GeoLite2-Country.mmdb]”, “cluster.uuid”: “NkExJ_5qRcSsazSpMv6rzQ”, “node.id”: “QLFhT197R8KRCibPK7mtUg” }
{“type”: “server”, “timestamp”: “2022-12-14T04:28:32,088Z”, “level”: “INFO”, “component”: “o.e.i.g.DatabaseNodeService”, “cluster.name”: “docker-cluster”, “node.name”: “c99f2a183c80”, “message”: “successfully reloaded changed geoip database file [/tmp/elasticsearch-207938627936206560/geoip-databases/QLFhT197R8KRCibPK7mtUg/GeoLite2-ASN.mmdb]”, “cluster.uuid”: “NkExJ_5qRcSsazSpMv6rzQ”, “node.id”: “QLFhT197R8KRCibPK7mtUg” }
{“type”: “server”, “timestamp”: “2022-12-14T04:28:33,534Z”, “level”: “INFO”, “component”: “o.e.i.g.DatabaseNodeService”, “cluster.name”: “docker-cluster”, “node.name”: “c99f2a183c80”, “message”: “successfully reloaded changed geoip database file [/tmp/elasticsearch-207938627936206560/geoip-databases/QLFhT197R8KRCibPK7mtUg/GeoLite2-City.mmdb]”, “cluster.uuid”: “NkExJ_5qRcSsazSpMv6rzQ”, “node.id”: “QLFhT197R8KRCibPK7mtUg” }
How to solve this problem ?
Thank you
