Nextcloud version: 25.0.1
Operating system and version: Ubuntu 20.04.4
Apache or nginx version: Apache/2.4.41
PHP version: PHP 7.4.3
- Upload any image with a specific name
- Check (open) preview for this specific file
- Replace (do not delete) image with another file with the same specific name (including extension)
- Reopen preview for this file: you will see an old preview for file that was uploaded on step one.
'passwordsalt' => '',
'secret' => '',
0 => '',
1 => '',
2 => '',
3 => '',
'datadirectory' => '',
'dbtype' => 'pgsql',
'version' => '25.0.1.1',
'overwrite.cli.url' => '',
'dbname' => '',
'dbhost' => 'localhost',
'dbuser' => '',
'dbpassword' => '',
'instanceid' => '',
'default_phone_region' => 'RU',
'log_type' => 'file',
'loglevel' => '2',
'log.condition' =>
'apps' =>
0 => 'admin_audit',
'auth.bruteforce.protection.enabled' => false,
'mail_smtpmode' => 'smtp',
'logtimezone' => 'Europe/Moscow',
'ldapIgnoreNamingRules' => false,
'theme' => '',
'mail_smtpsecure' => 'tls',
'mail_from_address' => '',
'mail_domain' => '',
'mail_smtphost' => '',
'mail_smtpport' => '',
'mail_smtpauth' => 1,
'mail_smtpname' => '',
'mail_smtppassword' => '',
'skeletondirectory' => '/var/www/nextcloud/default-files',
'preview_libreoffice_path' => '/usr/bin/libreoffice',
'enable_previews' => true,
'preview_max_memory' => 10000,
'jpeg_quality' => 60,
'preview_max_x' => 512,
'preview_max_y' => 512,
'preview_max_scale_factor' => 1,
'enabledPreviewProviders' =>
0 => 'OC\\Preview\\TXT',
1 => 'OC\\Preview\\MarkDown',
2 => 'OC\\Preview\\OpenDocument',
3 => 'OC\\Preview\\PDF',
4 => 'OC\\Preview\\MSOffice2003',
5 => 'OC\\Preview\\MSOfficeDoc',
6 => 'OC\\Preview\\Image',
7 => 'OC\\Preview\\Photoshop',
8 => 'OC\\Preview\\TIFF',
9 => 'OC\\Preview\\SVG',
10 => 'OC\\Preview\\Font',
11 => 'OC\\Preview\\MP3',
12 => 'OC\\Preview\\Movie',
13 => 'OC\\Preview\\MKV',
14 => 'OC\\Preview\\MP4',
15 => 'OC\\Preview\\AVI',
'templatedirectory' => '',
'redis' =>
'host' => '127.0.0.1',
'port' => 6379,
'app_install_overwrite' =>
0 => 'limit_login_to_ip',
1 => 'hancomoffice',
'updater.secret' => '',
