Step 2 (where I’m supposed to come to a login page) the page is just blank / white
I have tried to uninstall /install the app about 10 times now, same problem. Installed the app on 2 other Macbook Pro’s and never experienced this problem.
You can put this topic as solved.
The v.2.5.x to v.2.6.3 were really buggy.
But i don’t have problems with v.2.6.4 anymore.
If you have blank page usually it’s a problem on your server or the client because ssl handshake worked bad.
Indeed. I was frustrated for a few days with this having a fresh install of macOS on an old MacBook Air. The latest version still gives this undesirable behavior where I cannot actually log in once I’ve entered the server information. Just a white screen with a blue bar and with the buttons for “back” and “next” cut off the bottom of the screen to boot. Using the older version that was linked to here works fine, however.
Worked perfectly and synced right off the bat. So i then decided for kicks to try and download the newest version 3.1.3 since I had it to see if it would upgrade good and work!
It worked perfectly and upgraded and now works great! Thank you
