Problem with fuse filesystem - not visible in NC
    • Ubuntu 24.04 LTS
    • Apache/2.4.58
    • not installed
    • PHP 8.3.6 (cli)
    • Yes
    • not sure, but probably after manual scan
    • Bare Metal
    • NO
I’m using Google drive mounted via google_drive_ocamlfuse to one of directories under /mnt then I’m binding this folder to NC user files directory using fstab. Every 15 minutes I run cron action to syncronize Google drive with NC.
Mounting of Google drive is realized as service, it is done with option -o allow_other, also in fuse.conf file there is user_allow_other uncommented.
With this config I was able to connect google drives of users to thier NC files, but after last manual scan NC doesn’t see files binded.
All permisions are set to www-data user, chmod is 755 for binded folder. Verification via ls -l is showing all files owned by www-data.
  1. Add some files to NC data folder
  2. Run external scan as www-data
NOT NECESSARY IMO
NOT NECESSARY IMO
NOT NECESSARY IMO
            "***REMOVED SENSITIVE VALUE***",
        "dbtype": "mysql",
        "version": "31.0.6.2",
        "overwrite.cli.url": "***REMOVED SENSITIVE VALUE***",
        "dbport": "",
        "mysql.utf8mb4": true,
        "default_language": "pl",
        "default_locale": "pl_PL",
        "default_phone_region": "PL",
        "redis": {
            "port": 0
        "htaccess.RewriteBase": "\/",
        "memories.exiftool": "\/var\/www\/nextcloud\/apps\/memories\/bin-ext\/exiftool-amd64-glibc",
        "memories.vod.path": "\/var\/www\/nextcloud\/apps\/memories\/bin-ext\/go-vod-amd64",
        "theme": "",
        "loglevel": 2,
        "memories.gis_type": 1,
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "pipe",
        "mail_smtpsecure": "ssl",
        "mail_smtpport": "465",
        "mail_smtpauth": true,
        "enabledPreviewProviders": [
            "OC\\Preview\\Image",
            "OC\\Preview\\HEIC",
            "OC\\Preview\\TIFF",
            "OC\\Preview\\Movie"
        "memories.vod.disable": false,
        "memories.vod.vaapi": true
  • activity: 4.0.0
  • app_api: 5.0.2
  • bruteforcesettings: 4.0.0
  • calendar: 5.3.4
  • circles: 31.0.0
  • comments: 1.21.0
  • contacts: 7.1.4
  • contactsinteraction: 1.12.0
  • dashboard: 7.11.0
  • dav: 1.33.0
  • federation: 1.21.0
  • files: 2.3.1
  • files_downloadlimit: 4.0.0
  • files_external: 1.23.0
  • files_pdfviewer: 4.0.0
  • files_reminders: 1.4.0
  • files_sharing: 1.23.1
  • files_trashbin: 1.21.0
  • files_versions: 1.24.0
  • firstrunwizard: 4.0.0
  • group_everyone: 0.1.17
  • logreader: 4.0.0
  • mail: 5.1.6
  • memories: 7.6.0
  • notes: 4.12.1
  • notifications: 4.0.0
  • oauth2: 1.19.1
  • password_policy: 3.0.0
  • photos: 4.0.0-dev.1
  • previewgenerator: 5.8.0
  • privacy: 3.0.0
  • profile: 1.0.0
  • provisioning_api: 1.21.0
  • recognize: 9.0.3
  • recommendations: 4.0.0
  • related_resources: 2.0.0
  • richdocuments: 8.7.1
  • richdocumentscode: 25.4.202
  • serverinfo: 3.0.0
  • settings: 1.14.0
  • sharebymail: 1.21.0
  • support: 3.0.0
  • survey_client: 3.0.0
  • systemtags: 1.21.1
  • text: 5.0.0
  • theming: 2.6.1
  • updatenotification: 1.21.0
  • user_status: 1.11.0
  • viewer: 4.0.0
  • weather_status: 1.11.0
  • webhook_listeners: 1.2.0
  • workflowengine: 2.13.0
  • admin_audit: 1.21.0 (installed 1.21.0)
  • encryption: 2.19.0
  • spreed: 21.0.3 (installed 21.0.3)
  • suspicious_login: 9.0.1
  • user_ldap: 1.22.0
What happens when you run the scan in verbose mode (-v)?
Hi @jtr, nothing interesting was given in verbose scanning mode. Anyway it seems I’m closer to solve the problem. It is connected with the way I’m mounting fuse filesystem to NC. As I have written I’m using 2 steps:
  1. I’m starting service mounting fuse Google Drive filesystem to specific folder - lets say /mnt/google
  2. I’m using binding in fstab between /mnt/google folder and folder in NC - lets say /nc/username/files/Google
Rootcause of the problem is that sequece in fact is oposite - fstab binding is done before systemd service starts, so NC is able to see empty folder during start, then service starts and folder is linked with fuse Google Drive, but NC is not able to detect this situation (no idea why - ls sees those files normally)
So probably when I restarted my system this situation occured, it was not caused by launching manual scanning, but it happened after restart.
To fix this issue it seems I need to mount fuse filesystem directly into NC files.
