Nextcloud version (eg, 20.0.5): 19.9.1
Operating system and version (eg, Ubuntu 20.04): CentOS 7.9
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.6
PHP version (eg, 7.4): PHP 7.4
I have a problem with hidden files on a resource connected via SMB. I have two instances of nextcloud production and test version 19.09. On the test instance files with . are visible while on the production instance not. I would like that on production instance was the same as on test instance. For testing I connected the same resource to two instances and the problem looks like this:
I checked permissions: nextcloud files, user to connected external resources, nextcloud configuration files, versions of all apps.
No server logs (ERROR and CRITICAL)
One or more entries are hidden by the log level filter
'instanceid' => 'xxx',
'passwordsalt' => 'xxx',
'secret' => 'xxx',
0 => 'xxx',
1 => 'xxx',
'datadirectory' => '/var/www/html/nextcloud/data',
'version' => '19.0.9.1',
'dbname' => 'xxx',
'dbhost' => 'xxx',
'dbuser' => 'xxx',
'dbpassword' => 'xxx',
'loglevel' => 0,
'knowledgebaseenabled' => false,
'skeletondirectory' => '/opt/nextcloud-skeleton',
'enable_avatars' => false,
'allow_user_to_change_display_name' => false,
'enable_previews' => false,
'default_language' => 'pl',
'auth.bruteforce.protection.enabled' => false,
'has_internet_connection' => true,
'filelocking.enabled' => false,
'overwrite.cli.url' => 'https://xxx',
'overwritewebroot' => '/',
'mail_smtpmode' => 'smtp',
'trashbin_retention_obligation' => '7,8',
'versions_retention_obligation' => '7,8',
'redis' =>
'host' => '/var/run/redis/redis.sock',
'port' => 0,
'password' => 'xxx',
'proxy' => 'xxx',
'mail_from_address' => 'xxx',
'mail_domain' => 'xxx',
'mail_smtphost' => 'xxx',
'mail_smtpport' => '25',
'app_install_overwrite' =>
0 => 'files_accesscontrol',
