example
longer
example
here
Nextcloud version ( 27.1.1)
Operating system and version ( Linux 4.18.0-425.10.1.lve.el7h.x86_64 x86_64)
Apache or nginx version (Apache 8.2.4)
PHP version ( 8.2.4)
I decided to change the location of ftp storage from FTP to / so that by default it was uploaded to it, but it was not changed in the location of the account
Is this the first time you’ve seen this error? (Y):
- create ftp storage
- change the path of the ftp storage folder
no app in context Unable to get last modified date for ftp folder (), folder contents doesn't include current folder
'instanceid' => '*******',
'passwordsalt' => '*******',
'secret' => '*******',
0 => '*******',
'datadirectory' => '/var/www/s224444/data/www/*******/data',
'version' => '27.1.1.0',
'overwrite.cli.url' => '*******',
'dbname' => 'cloud',
'dbhost' => 'localhost',
'dbuser' => '*******',
'dbpassword' => '*******',
'app_install_overwrite' =>
0 => 'customproperties',
1 => 'sharepermissions',
2 => 'workflow_media_converter',
3 => 'flowupload',
4 => 'transfer',
5 => 'files_frommail',
6 => 'ransomware_protection',
7 => 'transmission',
8 => 'printer',
9 => 'gpxedit',
10 => 'epubreader',
11 => 'gpxmotion',
'twofactor_enforced' => 'false',
