Since tonight my MariaDB service is down and nextcloud says:
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
So in logs i can see this:
Doctrine\DBAL\DBALException: Failed to connect to the database: An exception occurred in driver: SQLSTATE[HY000] [2002] Connection refused in /var/www/nextcloud/lib/private/DB/Connection.php:64
Stack trace:
#0 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(420): OC\DB\Connection->connect()
#1 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(380): Doctrine\DBAL\Connection->getDatabasePlatformVersion()
#2 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(324): Doctrine\DBAL\Connection->detectDatabasePlatform()
#3 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(683): Doctrine\DBAL\Connection->getDatabasePlatform()
#4 /var/www/nextcloud/lib/private/DB/Connection.php(151): Doctrine\DBAL\Connection->setTransactionIsolation(2)
#5 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(195): OC\DB\Connection->__construct(Array, Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(Doctrine\DBAL\Configuration), Object(Doctrine\Common\EventManager))
#6 /var/www/nextcloud/lib/private/DB/ConnectionFactory.php(156): Doctrine\DBAL\DriverManager::getConnection(Array, Object(Doctrine\DBAL\Configuration), Object(Doctrine\Common\EventManager))
#7 /var/www/nextcloud/lib/private/Server.php(635): OC\DB\ConnectionFactory->getConnection(āmysqlā, Array)
#8 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC{closure}(Object(OC\Server))
#9 /var/www/nextcloud/lib/private/ServerContainer.php(120): Pimple\Container->offsetGet(āOCP\IDBConnectiā¦ā)
#10 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(161): OC\ServerContainer->query(āOCP\IDBConnectiā¦ā)
#11 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility{closure}(Object(OC\Server))
#12 /var/www/nextcloud/lib/private/ServerContainer.php(120): Pimple\Container->offsetGet(āDatabaseConnectā¦ā)
#13 /var/www/nextcloud/lib/private/Server.php(1554): OC\ServerContainer->query(āDatabaseConnectā¦ā)
#14 /var/www/nextcloud/lib/private/Server.php(362): OC\Server->getDatabaseConnection()
#15 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC{closure}(Object(OC\Server))
#16 /var/www/nextcloud/lib/private/ServerContainer.php(120): Pimple\Container->offsetGet(āOC\Authenticatiā¦ā)
#17 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(69): OC\ServerContainer->query(āOC\Authenticatiā¦ā, true)
#18 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(99): OC\AppFramework\Utility\SimpleContainer->buildClass(Object(ReflectionClass))
#19 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(114): OC\AppFramework\Utility\SimpleContainer->resolve(āOC\Authenticatiā¦ā)
#20 /var/www/nextcloud/lib/private/ServerContainer.php(145): OC\AppFramework\Utility\SimpleContainer->query(āOC\Authenticatiā¦ā, true)
#21 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(69): OC\ServerContainer->query(āOC\Authenticatiā¦ā, true)
#22 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(99): OC\AppFramework\Utility\SimpleContainer->buildClass(Object(ReflectionClass))
#23 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(114): OC\AppFramework\Utility\SimpleContainer->resolve(āOC\Authenticatiā¦ā)
#24 /var/www/nextcloud/lib/private/ServerContainer.php(145): OC\AppFramework\Utility\SimpleContainer->query(āOC\Authenticatiā¦ā, true)
#25 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(161): OC\ServerContainer->query(āOC\Authenticatiā¦ā)
#26 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility{closure}(Object(OC\Server))
#27 /var/www/nextcloud/lib/private/ServerContainer.php(120): Pimple\Container->offsetGet(āOC\Authenticatiā¦ā)
#28 /var/www/nextcloud/lib/private/Server.php(374): OC\ServerContainer->query(āOC\Authenticatiā¦ā)
#29 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC{closure}(Object(OC\Server))
#30 /var/www/nextcloud/lib/private/ServerContainer.php(120): Pimple\Container->offsetGet(āOC\User\Sessionā)
#31 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(161): OC\ServerContainer->query(āOC\User\Sessionā)
#32 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility{closure}(Object(OC\Server))
#33 /var/www/nextcloud/lib/private/ServerContainer.php(120): Pimple\Container->offsetGet(āUserSessionā)
#34 /var/www/nextcloud/lib/private/Server.php(1430): OC\ServerContainer->query(āUserSessionā)
#35 /var/www/nextcloud/lib/private/Server.php(688): OC\Server->getUserSession()
#36 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC{closure}(Object(OC\Server))
#37 /var/www/nextcloud/lib/private/ServerContainer.php(120): Pimple\Container->offsetGet(āOC\App\AppManagā¦ā)
#38 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(161): OC\ServerContainer->query(āOC\App\AppManagā¦ā)
#39 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility{closure}(Object(OC\Server))
#40 /var/www/nextcloud/lib/private/ServerContainer.php(120): Pimple\Container->offsetGet(āAppManagerā)
#41 /var/www/nextcloud/lib/private/Server.php(1725): OC\ServerContainer->query(āAppManagerā)
#42 /var/www/nextcloud/lib/private/legacy/app.php(346): OC\Server->getAppManager()
#43 /var/www/nextcloud/lib/private/legacy/app.php(114): OC_App::getEnabledApps()
#44 /var/www/nextcloud/lib/base.php(640): OC_App::loadApps(Array)
#45 /var/www/nextcloud/lib/base.php(1078): OC::init()
#46 /var/www/nextcloud/console.php(47): require_once(ā/var/www/nextclā¦ā)
#47 /var/www/nextcloud/occ(11): require_once(ā/var/www/nextclā¦ā)
May because of an auto-update tonight? Reboot does not help.
What to do?
