Nextcloud version : 18:07
Operating system and version : Debian 10
Nginx version : 1.14.2
PHP version : 7.3.7
Installed in LXC container under Proxmox
I have a nextcloud instance, which I had kept in case of a problem with the current one, where I stored several GB of important data, except that nextcloud had built-in encryption activated.
So I tried to force the decryption except that it doesn’t work, and I got this out of the command: https://pastebin.com/uyE2Enn0
- sudo -u www-data php occ encryption:decrypt-all
The output of config.php file
'instanceid' => ' ',
'passwordsalt' => ' ',
'secret' => ' ',
0 => 'cloud.example.org',
'version' => '18.0.7.1',
'overwrite.cli.url' => 'https://cloud.example.org',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextclouduser',
'dbpassword' => ' ',
'twofactor_enforced' => 'false',
'theme' => '',
'loglevel' => 2,
'app_install_overwrite' =>
0 => 'spreed',
1 => 'twofactor_yubikey',
2 => 'files_external_gdrive',
'trusted_proxies' =>
0 => 'localhost',
1 => 'cloud.example.org',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_from_address' => 'postmaster',
'mail_domain' => 'example.org',
'mail_smtphost' => 'ssl0.example.org',
'mail_smtpport' => '465',
'mail_smtpauth' => 1,
'mail_smtpname' => 'postmaster@example.org',
'mail_smtppassword' => ' ',
'updater.secret' => ' ',
