[details=“Support intro”]
Nextcloud version 18.1
Operating system and version UBUNTU 18.04LTS
Apache or nginx version
Server version: Apache/2.4.29 (Ubuntu)
Server built: 2019-09-16T12:58:48
PHP version
PHP 7.2.24-0ubuntu0.18.04.3 (cli) (built: Feb 11 2020 15:55:52) ( NTS )
Copyright © 1997-2018 The PHP Group
Zend Engine v3.2.0, Copyright © 1998-2018 Zend Technologies
with Zend OPcache v7.2.24-0ubuntu0.18.04.3, Copyright © 1999-2018, by Zend Technologies
The issue:
After installing NC and creating the admins account I first created a usergroup and two users as members of this grp.
The users can login to nextcloud, no problem there.
But when I login as admin, the created usergroup and the two users are not shown when using the user-management.
(Because I use german language I only can post the german messages.)
action: klicking the “Benutzer”-Icon is followed by the error-message
“Es ist ein Fehler bei der Anfrage aufgetreten. Es kann nicht fortgefahren werden.”
The same message occurs, whe I klick one of the items
- Jeder
- Administratoren
- Gruppen
– and the items related to the created groups.
it’s a fresh install!. Getting this error-message I rrepeated the installation-procedure repeated after cleaning the appropriate folders and config-files.
the mysql-server is running stable without problems. It’s using innodb/barracuda,
Steps to replicate it: ??
***"]},{"file":"/var/www/html/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":73,"function":"callListeners","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->","args":[[{"__class__":"Closure"},{"__class__":"Closure"}],"*** sensitive parameter replaced ***","*** sensitive parameter replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/EventDispatcher/EventDispatcher.php","line":80,"function":"dispatch","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->","args":["*** sensitive parameter replaced ***","*** sensitive parameter replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/EventDispatcher/EventDispatcher.php","line":92,"function":"dispatch","class":"OC\\EventDispatcher\\EventDispatcher","type":"->","args":["*** sensitive parameter replaced ***","*** sensitive parameter replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/User/Database.php","line":136,"function":"dispatchTyped","class":"OC\\EventDispatcher\\EventDispatcher","type":"->","args":["*** sensitive parameter replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/User/Manager.php","line":370,"function":"createUser","class":"OC\\User\\Database","type":"->","args":["*** sensitive parameter replaced ***","*** sensitive parameter replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/User/Manager.php","line":315,"function":"createUserFromBackend","class":"OC\\User\\Manager","type":"->","args":["*** sensitive parameter replaced ***","*** sensitive parameter replaced ***",{"__class__":"OC\\User\\Database"}]},{"file":"/var/www/html/nextcloud/apps/provisioning_api/lib/Controller/UsersController.php","line":314,"function":"createUser","class":"OC\\User\\Manager","type":"->","args":["*** sensitive parameter replaced ***","*** sensitive parameter replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":170,"function":"addUser","class":"OCA\\Provisioning_API\\Controller\\UsersController","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":99,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Provisioning_API\\Controller\\UsersController"},"addUser"]},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/App.php","line":125,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Provisioning_API\\Controller\\UsersController"},"addUser"]},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Routing/RouteActionHandler.php","line":47,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Provisioning_API\\Controller\\UsersController","addUser",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"_route":"ocs.provisioning_api.Users.addUser"}]},{"function":"__invoke","class":"OC\\AppFramework\\Routing\\RouteActionHandler","type":"->","args":[{"_route":"ocs.provisioning_api.Users.addUser"}]},{"file":"/var/www/html/nextcloud/lib/private/Route/Router.php","line":299,"function":"call_user_func","args":[{"__class__":"OC\\AppFramework\\Routing\\RouteActionHandler"},{"_route":"ocs.provisioning_api.Users.addUser"}]},{"file":"/var/www/html/nextcloud/ocs/v1.php","line":82,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/ocsapp/cloud/users"]},{"file":"/var/www/html/nextcloud/ocs/v2.php","line":24,"args":["/var/www/html/nextcloud/ocs/v1.php"],"function":"require_once"}],"File":"/var/www/html/nextcloud/apps/password_policy/lib/Validator/CommonPasswordsValidator.php","Line":53,"Hint":"Das Passwort ist unter den 1.000.000 h\u00e4ufigsten Passw\u00f6rtern. Bitte w\u00e4hle ein anderes.","CustomMessage":"Failed addUser attempt with hint exception."},"userAgent":"Mozilla/5.0 (Windows NT 6.1; rv:45.0) Gecko/20100101 Firefox/45.0","version":"18.0.1.3"}
{"reqId":"ifcrerCc7u3xwauMMl1g","level":2,"time":"March 02, 2020 09:08:40","remoteAddr":"invoking_from_address","user":"admins_name","app":"ocs_api","method":"POST","url":"/ocs/v2.php/cloud/users","message":{"Exception":"OC\\HintException","Message":"Password is among the 1,000,000 most common ones. Please make it unique.","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/apps/password_policy/lib/PasswordValidator.php","line":77,"function":"validate","class":"OCA\\Password_Policy\\Validator\\CommonPasswordsValidator","type":"->","args":["*** sensitive parameter replaced ***"]},{"file":"/var/www/html/nextcloud/apps/password_policy/lib/AppInfo/Application.php","line":59,"function":"validate","class":"OCA\\Password_Policy\\PasswordValidator","type":"->","args":["*** sensitive parameter replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":247,"function":"OCA\\Password_Policy\\AppInfo\\{closure}","class":"OCA\\Password_Policy\\AppInfo\\Application","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":73,"function":"callListeners","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->","args":[[{"__class__":"Closure"},{"__class__":"Closure"}],"*** sensitive parameter replaced ***","*** sensitive parameter replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/EventDispatcher/EventDispatcher.php","line":80,"function":"dispatch","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->","args":["*** sensitive parameter replaced ***","*** sensitive parameter replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/EventDispatcher/EventDispatcher.php","line":92,"function":"dispatch","class":"OC\\EventDispatcher\\EventDispatcher","type":"->","args":["*** sensitive parameter replaced ***","*** sensitive parameter replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/User/Database.php","line":136,"function":"dispatchTyped","class":"OC\\EventDispatcher\\EventDispatcher","type":"->","args":["*** sensitive parameter replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/User/Manager.php","line":370,"function":"createUser","class":"OC\\User\\Database","type":"->","args":["*** sensitive parameter replaced ***","*** sensitive parameter replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/User/Manager.php","line":315,"function":"createUserFromBackend","class":"OC\\User\\Manager","type":"->","args":["*** sensitive parameter replaced ***","*** sensitive parameter replaced ***",{"__class__":"OC\\User\\Database"}]},{"file":"/var/www/html/nextcloud/apps/provisioning_api/lib/Controller/UsersController.php","line":314,"function":"createUser","class":"OC\\User\\Manager","type":"->","args":["*** sensitive parameter replaced ***","*** sensitive parameter replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":170,"function":"addUser","class":"OCA\\Provisioning_API\\Controller\\UsersController","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":99,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Provisioning_API\\Controller\\UsersController"},"addUser"]},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/App.php","line":125,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Provisioning_API\\Controller\\UsersController"},"addUser"]},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Routing/RouteActionHandler.php","line":47,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Provisioning_API\\Controller\\UsersController","addUser",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"_route":"ocs.provisioning_api.Users.addUser"}]},{"function":"__invoke","class":"OC\\AppFramework\\Routing\\RouteActionHandler","type":"->","args":[{"_route":"ocs.provisioning_api.Users.addUser"}]},{"file":"/var/www/html/nextcloud/lib/private/Route/Router.php","line":299,"function":"call_user_func","args":[{"__class__":"OC\\AppFramework\\Routing\\RouteActionHandler"},{"_route":"ocs.provisioning_api.Users.addUser"}]},{"file":"/var/www/html/nextcloud/ocs/v1.php","line":82,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/ocsapp/cloud/users"]},{"file":"/var/www/html/nextcloud/ocs/v2.php","line":24,"args":["/var/www/html/nextcloud/ocs/v1.php"],"function":"require_once"}],"File":"/var/www/html/nextcloud/apps/password_policy/lib/Validator/CommonPasswordsValidator.php","Line":53,"Hint":"Das Passwort ist unter den 1.000.000 h\u00e4ufigsten Passw\u00f6rtern. Bitte w\u00e4hle ein anderes.","CustomMessage":"Failed addUser attempt with hint exception."},"userAgent":"Mozilla/5.0 (Windows NT 6.1; rv:45.0) Gecko/20100101 Firefox/45.0","version":"18.0.1.3"}
{"reqId":"80SbMR2RCm16oRaGWTqU","level":2,"time":"March 02, 2020 09:08:43","remoteAddr":"invoking_from_address","user":"admins_name","app":"ocs_api","method":"POST","url":"/ocs/v2.php/cloud/users","message":{"Exception":"OC\\HintException","Message":"Password is among the 1,000,000 most common ones. Please make it unique.","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/apps/password_policy/lib/PasswordValidator.php","line":77,"function":"validate","class":"OCA\\Password_Policy\\Validator\\CommonPasswordsValidator","type":"->","args":["*** sensitive parameter replaced ***"]},{"file":"/var/www/html/nextcloud/apps/password_policy/lib/AppInfo/Application.php","line":59,"function":"validate","class":"OCA\\Password_Policy\\PasswordValidator","type":"->","args":["*** sensitive parameter replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":247,"function":"OCA\\Password_Policy\\AppInfo\\{closure}","class":"OCA\\Password_Policy\\AppInfo\\Application","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":73,"function":"callListeners","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->","args":[[{"__class__":"Closure"},{"__class__":"Closure"}],"*** sensitive parameter replaced ***","*** sensitive parameter replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/EventDispatcher/EventDispatcher.php","line":80,"function":"dispatch","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->","args":["*** sensitive parameter replaced ***","*** sensitive parameter replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/EventDispatcher/EventDispatcher.php","line":92,"function":"dispatch","class":"OC\\EventDispatcher\\EventDispatcher","type":"->","args":["*** sensitive parameter replaced ***","*** sensitive parameter replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/User/Database.php","line":136,"function":"dispatchTyped","class":"OC\\EventDispatcher\\EventDispatcher","type":"->","args":["*** sensitive parameter replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/User/Manager.php","line":370,"function":"createUser","class":"OC\\User\\Database","type":"->","args":["*** sensitive parameter replaced ***","*** sensitive parameter replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/User/Manager.php","line":315,"function":"createUserFromBackend","class":"OC\\User\\Manager","type":"->","args":["*** sensitive parameter replaced ***","*** sensitive parameter replaced ***",{"__class__":"OC\\User\\Database"}]},{"file":"/var/www/html/nextcloud/apps/provisioning_api/lib/Controller/UsersController.php","line":314,"function":"createUser","class":"OC\\User\\Manager","type":"->","args":["*** sensitive parameter replaced ***","*** sensitive parameter replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":170,"function":"addUser","class":"OCA\\Provisioning_API\\Controller\\UsersController","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":99,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Provisioning_API\\Controller\\UsersController"},"addUser"]},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/App.php","line":125,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Provisioning_API\\Controller\\UsersController"},"addUser"]},{"file":"/var/www/html/nextcloud/lib/private/AppFramework/Routing/RouteActionHandler.php","line":47,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Provisioning_API\\Controller\\UsersController","addUser",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"_route":"ocs.provisioning_api.Users.addUser"}]},{"function":"__invoke","class":"OC\\AppFramework\\Routing\\RouteActionHandler","type":"->","args":[{"_route":"ocs.provisioning_api.Users.addUser"}]},{"file":"/var/www/html/nextcloud/lib/private/Route/Router.php","line":299,"function":"call_user_func","args":[{"__class__":"OC\\AppFramework\\Routing\\RouteActionHandler"},{"_route":"ocs.provisioning_api.Users.addUser"}]},{"file":"/var/www/html/nextcloud/ocs/v1.php","line":82,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/ocsapp/cloud/users"]},{"file":"/var/www/html/nextcloud/ocs/v2.php","line":24,"args":["/var/www/html/nextcloud/ocs/v1.php"],"function":"require_once"}],"File":"/var/www/html/nextcloud/apps/password_policy/lib/Validator/CommonPasswordsValidator.php","Line":53,"Hint":"Das Passwort ist unter den 1.000.000 h\u00e4ufigsten Passw\u00f6rtern. Bitte w\u00e4hle ein anderes.","CustomMessage":"Failed addUser attempt with hint exception."},"userAgent":"Mozilla/5.0 (Windows NT 6.1; rv:45.0) Gecko/20100101 Firefox/45.0","version":"18.0.1.3"}
'instanceid' => 'ocb002pu13sz',
'passwordsalt' => '????????????????????????',
'secret' => '?????????????????????????????????',
0 => 'public_address',
1 => 'internal_address',
2 => 'localhost',
'datadirectory' => '/mnt/r1p1/nextcloud/data',
'version' => '18.0.1.3',
'overwrite.cli.url' => 'https://public_address',
'dbname' => 'nextclouddb',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => '???????',
'defaultapp' => 'files',
'allow_user_to_change_display_name' => true,
'auth.bruteforce.protection.enabled' => true,
'mail_from_address' => 'my_name',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'ist_set',
'mail_smtpsecure' => 'tls',
'mail_smtpauth' => 1,
'mail_smtphost' => 'is_set',
'mail_smtpport' => '587',
'mail_smtpname' => 'my_email_address',
'mail_smtppassword' => 'PW',
'log_type' => 'file',
'logfilemode' => 416,
'loglevel' => 1,
'syslog_tag' => 'Nextcloud',
'logdateformat' => 'F d, Y H:i:s',
'log_query' => false,
'log_rotate_size' => 104857600,
[Sun Mar 01 06:25:02.699620 2020] [mpm_prefork:notice] [pid 1515] AH00163: Apache/2.4.29 (Ubuntu) OpenSSL/1.1.1 configured -- resuming normal operations
[Sun Mar 01 06:25:02.699671 2020] [core:notice] [pid 1515] AH00094: Command line: '/usr/sbin/apache2'
[Sun Mar 01 16:16:51.948216 2020] [mpm_prefork:notice] [pid 1515] AH00169: caught SIGTERM, shutting down
[Sun Mar 01 16:16:52.134422 2020] [mpm_prefork:notice] [pid 23083] AH00163: Apache/2.4.29 (Ubuntu) OpenSSL/1.1.1 configured -- resuming normal operations
[Sun Mar 01 16:16:52.134527 2020] [core:notice] [pid 23083] AH00094: Command line: '/usr/sbin/apache2'
[Sun Mar 01 16:17:00.764045 2020] [mpm_prefork:notice] [pid 23083] AH00169: caught SIGTERM, shutting down
[Sun Mar 01 16:17:07.073558 2020] [mpm_prefork:notice] [pid 23190] AH00163: Apache/2.4.29 (Ubuntu) OpenSSL/1.1.1 configured -- resuming normal operations
[Sun Mar 01 16:17:07.073664 2020] [core:notice] [pid 23190] AH00094: Command line: '/usr/sbin/apache2'
[Sun Mar 01 16:39:51.780345 2020] [mpm_prefork:notice] [pid 23190] AH00169: caught SIGTERM, shutting down
[Sun Mar 01 16:39:51.959479 2020] [mpm_prefork:notice] [pid 23870] AH00163: Apache/2.4.29 (Ubuntu) OpenSSL/1.1.1 configured -- resuming normal operations
[Sun Mar 01 16:39:51.959583 2020] [core:notice] [pid 23870] AH00094: Command line: '/usr/sbin/apache2'
[Sun Mar 01 17:06:08.880204 2020] [mpm_prefork:notice] [pid 23870] AH00169: caught SIGTERM, shutting down
[Sun Mar 01 17:06:09.054771 2020] [mpm_prefork:notice] [pid 24202] AH00163: Apache/2.4.29 (Ubuntu) OpenSSL/1.1.1 configured -- resuming normal operations
[Sun Mar 01 17:06:09.054871 2020] [core:notice] [pid 24202] AH00094: Command line: '/usr/sbin/apache2'
[Sun Mar 01 18:47:20.010213 2020] [mpm_prefork:notice] [pid 24202] AH00169: caught SIGTERM, shutting down
[Sun Mar 01 18:51:14.273606 2020] [mpm_prefork:notice] [pid 29520] AH00163: Apache/2.4.29 (Ubuntu) OpenSSL/1.1.1 configured -- resuming normal operations
[Sun Mar 01 18:51:14.273715 2020] [core:notice] [pid 29520] AH00094: Command line: '/usr/sbin/apache2'
[Mon Mar 02 06:25:01.581400 2020] [mpm_prefork:notice] [pid 29520] AH00171: Graceful restart requested, doing restart
