Sorry to hear youâre facing problems
help.nextcloud.com is for home/non-enterprise users. If youâre running a business, paid support can be accessed via portal.nextcloud.com where we can ensure your business keeps running smoothly.
example
longer
example
here
Some or all of the below information will be requested if it isnât supplied; for fastest response please provide as much as you can
Nextcloud version (eg, 12.0.2): 13.0.5
Operating system and version (eg, Ubuntu 17.04): Centos 7
Apache or nginx version (eg, Apache 2.4.25): 2.4.6
PHP version (eg, 7.1): 7.0.27
The issue you are facing: I have an old Nextcloud instance that was first installed when it still was called Owncloud. It has been dormant for quite a while but now I took the time to upgrade it. After installing php7 from software collections for Centos I used the automatic upgrade tool to go from 10.x to 13.0.5. Everything looks OK except for contacts. There are some contacts that wonât open up anymore when using the web interface. Other contacts are OK.
Also contacts donât work at all when trying to access them from Evolution. I get
âThe address book backend servicing âContactsâ encountered an error. The reported error was âFailed to issue REPORT: HTTP error code 404 (Not Found): Sabre\DAV\Exception\NotFound
Card not found[exception][message]â.â
Calendar works fine from Evolution. Iâm using version 3.28.5 of Evolution on Fedora 28.
Is this the first time youâve seen this error? (Y/N): Y
journalctl -fl doesnât show anything when this error occurs.
PASTE HERE
PASTE HERE
