I using one host for both collabora and Nextcloud
you do not understand.
Hardware-Host: cloudserver
Virtual-Host: officeserver in docker container
apache reverse proxy:
cloudserver:443 -> locahost:443
officeserver:443 -> localhost:9980
have you resolved your problem?
show your config php, i wanna compare with mine config.php
sorry for late reponse.
This is my apache proxy config:
The SSL Cert Path is deleted. I use Plesk Onyx.
# SSL configuration, you may want to take the easy route instead and use Lets Encrypt!
SSLEngine on
SSLProtocol all -SSLv2 -SSLv3
SSLCipherSuite ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS
SSLHonorCipherOrder on
# Encoded slashes need to be allowed
AllowEncodedSlashes NoDecode
# Container uses a unique non-signed certificate
SSLProxyEngine On
SSLProxyVerify None
SSLProxyCheckPeerCN Off
SSLProxyCheckPeerName Off
# keep the host
ProxyPreserveHost On
# static html, js, images, etc. served from loolwsd
# loleaflet is the client part of LibreOffice Online
ProxyPass /loleaflet https://127.0.0.1:9980/loleaflet retry=0
ProxyPassReverse /loleaflet https://127.0.0.1:9980/loleaflet
# WOPI discovery URL
ProxyPass /hosting/discovery https://127.0.0.1:9980/hosting/discovery retry=0
ProxyPassReverse /hosting/discovery https://127.0.0.1:9980/hosting/discovery
# Main websocket
ProxyPassMatch "/lool/(.*)/ws$" wss://127.0.0.1:9980/lool/$1/ws nocanon
# Admin Console websocket
ProxyPass /lool/adminws wss://127.0.0.1:9980/lool/adminws
# Download as, Fullscreen presentation and Image upload operations
ProxyPass /lool https://127.0.0.1:9980/lool
ProxyPassReverse /lool https://127.0.0.1:9980/lool
Maybe this helps?
[ client_ws_0001 ] ERR ClientRequestHandler::handleClientRequest: Exception: Invalid URI.| wsd/LOOLWSD.cpp:1245
Google Chrome Error Console:
WebSocket connection to 'wss://office.domain.tld/lool/%3Fpermission%3Dedit/ws' failed: Invalid frame header
I have this found at the logs.
Errorno app in context2017-02-02T12:05:49+0100
OCP\AppFramework\QueryException: Could not resolve OCA\Richdocuments\Settings\Section! Class OCA\Richdocuments\Settings\Section does not exist
Errorno app in context2017-02-02T12:05:40+0100
Errorno app in context2017-02-01T22:36:19+0100
Errorno app in context2017-02-01T20:22:49+0100
Errorno app in context2017-02-01T20:22:28+0100
/var/www/vhosts/domain.tld/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 117: OC\AppFramework\Utility\SimpleContainer->resolve('OCA\\Richdocumen...')
/var/www/vhosts/domain.tld/nextcloud/lib/private/ServerContainer.php - line 89: OC\AppFramework\Utility\SimpleContainer->query('OCA\\Richdocumen...')
/var/www/vhosts/domain.tld/nextcloud/lib/private/Settings/Manager.php - line 319: OC\ServerContainer->query('OCA\\Richdocumen...')
/var/www/vhosts/domain.tld/nextcloud/lib/private/Settings/Manager.php - line 353: OC\Settings\Manager->query('OCA\\Richdocumen...')
/var/www/vhosts/domain.tld/nextcloud/settings/Controller/AdminSettingsController.php - line 131: OC\Settings\Manager->getAdminSections()
/var/www/vhosts/domain.tld/nextcloud/settings/Controller/AdminSettingsController.php - line 70: OC\Settings\Controller\AdminSettingsController->getNavigationParameters('server')
[internal function] OC\Settings\Controller\AdminSettingsController->index('server')
/var/www/vhosts/domain.tld/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 160: call_user_func_array(Array, Array)
/var/www/vhosts/domain.tld/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 90: OC\AppFramework\Http\Dispatcher->executeController(Object(OC\Settings\Controller\AdminSettingsController), 'index')
/var/www/vhosts/domain.tld/nextcloud/lib/private/AppFramework/App.php - line 114: OC\AppFramework\Http\Dispatcher->dispatch(Object(OC\Settings\Controller\AdminSettingsController), 'index')
/var/www/vhosts/domain.tld/nextcloud/lib/private/AppFramework/Routing/RouteActionHandler.php - line 47: OC\AppFramework\App main('OC\\Settings\\Con...', 'index', Object(OC\AppFramework\DependencyInjection\DIContainer), Array)
[internal function] OC\AppFramework\Routing\RouteActionHandler->__invoke(Array)
/var/www/vhosts/domain.tld/nextcloud/lib/private/Route/Router.php - line 299: call_user_func(Object(OC\AppFramework\Routing\RouteActionHandler), Array)
/var/www/vhosts/domain.tld/nextcloud/lib/base.php - line 1010: OC\Route\Router->match('/settings/admin')
/var/www/vhosts/domain.tld/nextcloud/index.php - line 40: OC handleRequest()
{main}
Shouldnât it be:
docker run -t -d -p 127.0.0.1:9980:9980 -e âdomain=cloudhost\\.domain\\.tldâ --restart always --cap-add MKNOD collabora/code
(Sorry if this has been brought up alreadyâŚ)
hmm no i get this error when i acces one doc file and the âpermission deniedâ message appears.
2017-02-05 10:42:38 Error (111)Connection refused: AH00957: HTTPS: attempt to connect to 127.0.0.1:9980 (127.0.0.1) failed Apache-Fehler
2017-02-05 10:42:38 Error AH00959: ap_proxy_connect_backend disabling worker for (127.0.0.1) for 0s Apache-Fehler
2017-02-05 10:42:38 Error 5.10.188.170 AH01114: HTTP: failed to make connection to backend: 127.0.0.1 Apache-Fehler
2017-02-05 10:42:42 Error 5.10.188.170 503 GET /hosting/discovery HTTP/1.1 Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/55.0.2883.87 Safari/537.36 1.47 K SSL/TLS-Zugriff fĂźr Apache
2017-02-05 10:42:42 Error (111)Connection refused: AH00957: HTTPS: attempt to connect to 127.0.0.1:9980 (127.0.0.1) failed Apache-Fehler
2017-02-05 10:42:42 Error AH00959: ap_proxy_connect_backend disabling worker for (127.0.0.1) for 0s Apache-Fehler
2017-02-05 10:42:42 Error 5.10.188.170 AH01114: HTTP: failed to make connection to backend: 127.0.0.1 Apache-Fehler
2017-02-05 10:43:39 Error 5.10.188.170 502 GET /hosting/discovery HTTP/1.1 Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/55.0.2883.87 Safari/537.36 1.56 K SSL/TLS-Zugriff fĂźr Apache
2017-02-05 10:43:39 Error 5.10.188.170 (103)Software caused connection abort: AH01102: error reading status line from remote server 127.0.0.1:9980 Apache-Fehler
2017-02-05 10:43:39 Error 5.10.188.170 AH00898: Error reading from remote server returned by /hosting/discovery
Has the docker image even started? What does âdocker psâ print out?
here some new logs:
GET /lool/https%3A%2F%2Fcloud.larsmueller.net%2Findex.php%2Fapps%2Frichdocuments%2Fwopi%2Ffiles%2F3_oc5ly9kwuaz5%3Faccess_token%3Dp8mzBvnb2tcGHg1nbGz0MEBXREneCJkg%26access_token_ttl%3D0%26permission%3Dedit/ws HTTP/1.1
and docker logs give me this:
wsd-00026-0028 17:14:46.807698 [ client_req_hdl ] WRN WOPI host did not pass optional access_token_ttl| wsd/FileServer.cpp:255
wsd-00026-0027 17:14:47.653954 [ client_ws_0003 ] ERR Error in client request handler: No acceptable WOPI hosts found matching the target host [cloud.larsmueller.net] in config.| wsd/LOOLWSD.cpp:1031
edit: problem solved! Collabora works again
So how did you solve this?
Could you please share? Thank you!
I change the URL at the docker image to the cloud domain ,not the office domain. Then it works.
Like this
docker run -t -d -p 127.0.0.1:9980:9980 -e 'domain=cloud\\.nextcloud\\.com' --restart always --cap-add MKNOD collabora/code
But at the nextcloud Backend enter the https://office.domain.tld
Hello!
I have the same error with âPermission Deniedâ.
Iâve use this manual Integrate Collabora Online with Nextcloud on Ubuntu with Docker step by step.
but the problem appear.
Can someone help me?
sudo docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES ff2abe37bdc7 collabora/code "/bin/sh -c 'bash sta" 6 minutes ago Restarting (1) 2 minutes ago 127.0.0.1:9980->9980/tcp cocky_dubinsky
sudo docker run -t -d -p 127.0.0.1:9980:9980 -e âdomain=nextcloud\.corpdomain\.comâ --restart always --cap-add MKNOD collabora/code
Config URL at nextcloud backend
https://office.nextcloud.corpdomain.com
Config of /etc/apache2/sites-enabled/office.corpdomain.com-le-ssl.conf edited based on CODE 2.0 updates - Collabora Office and Collabora Online
ServerName office.corpdomain.com
SSLCertificateFile /etc/letsencrypt/live/office.your-domain.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/office.your-domain.com/privkey.pem
SSLProxyEngine On
SSLProxyVerify None
keep the host
WOPI discovery URL
Main websocket
ProxyPassMatch â/lool/(.*)/ws$â wss://127.0.0.1:9980/lool/$1/ws nocanon
Where is my problem?
UPD
Apache log
[Fri Feb 10 14:40:22.409045 2017] [proxy_http:error] [pid 3732] (103)Software caused connection abort: [client 127.0.0.1:35184] AH01102: error reading status line from remote server 127.0.0.1:9980
[Fri Feb 10 14:40:22.409255 2017] [proxy:error] [pid 3732] [client 127.0.0.1:35184] AH00898: Error reading from remote server returned by /hosting/discovery
office.nextcloud.corpdomain.com:443 127.0.0.1 - - [10/Feb/2017:14:40:22 +0100] âGET /hosting/discovery HTTP/1.1â 502 3749 â-â âownCloud Server Crawlerâ
The problem with my proxy? With docker or proxy Apache conf ?
502 Proxy ErrorProxy Error
The proxy server received an invalid response from an upstream server.
The proxy server could not handle the request GET /lool.Reason: Error reading from remote server
Apache/2.4.18 (Ubuntu) Server at office.corpdomain.com Port 443
So, problem with Apache proxy config or Docker ?
but under nextcloud i setup âoffice.corpdomain.comâ as adress.
my Docker logs showing this before:
No acceptable WOPI hosts found matching the target host [YOUR NEXTCLOUD DOMAIN] in config.
Unauthorized WOPI host. Please try again later and report to your administrator if the issue persists.
This is my vhost_ssl.conf
ServerName office.corpdomai.com:443
SSLEngine on
SSLProxyEngine On
SSLProxyVerify None
# keep the host
# Main websocket
maybe it helps.
I know itâs a late reply but I wanted to add to the conversation a possible solution. I had the same error and the the solution in selinux blocking apache.
usr/sbin/setsebool -P httpd_can_network_connect 1
Did the trick for me.
