Problem with Collabora
I installed Collab on my Nextcloud Server just like the instruction here : https://nextcloud.com/collaboraonline/
But if i activate Collab under Production/Office -> there appears no Office Icon in the App Dashboard. Can someone help me?
It’s an Feature. You can add documents with the :heavy_plus_sign: Icon
But the guy here : http://prntscr.com/dx5hrc has a Icon called Office after the activation of Collabora Online.
I think that is an old Version.
That could be possible…
Okay thanks! But I have one more question.
I’ve installed Collab now and if I try to open a document like .odt there comes a new Window with Permission Denied (the .htaccess is correct)
did you edit the reverse proxy config? there are some changes in version 2.
look at this page https://www.collaboraoffice.com/community-en/code-2-0-updates-2/
I have the same issue.
Dominik Hebestreit noreply@nextcloud.com schrieb am Mi., 18. Jan. 2017,
13:31:
yes and Apache2 as proxy.
Same problem.
Haven’t icon Office after Collabora Online (v.1.1.25) activated
If open document then have lockscreen Access Denied
Any solution?
I can’t find any post on github yet. I think it’s a new problem. Shall we report that problem?
yes, it looks like we have the same issue on this thread:
https://help.nextcloud.com/t/collabora-and-nextcloud-11/6653
and yes, please, report :smiley:
look at your virtual host config file. you must use full hostnames and no ip-addresses.
for example:
<VirtualHost *:443>
ServerName host.domain.tld:443
i know it. office,domain.tld is set as adress to collabora.
docker run -t -d -p 9980:9980 -e "domain=office.example.com" --cap-add MKNOD collabora/code
and https://office.example.com and the Nextcloud Backend.
@Lars_M how did you install your Docker?
not your docker startup. you should verify you vhost config for apache reverse proxy.
VirtualHost *:443
/VirtualHost
your docker startup should be:
docker run -t -d -p 127.0.0.1:9980:9980 -e ā€˜domain=cloudhost.domain.tld’ --restart always --cap-add MKNOD collabora/code
yes it“s listening to 127.0.0.1:9980 and cloud.domain.tld that is not my problem.
when i enter the URL manually i get this:
https://cloud.domain.tld/loleaflet/2.0.1/loleaflet.html
and /hosting/discovery
i get the XML Part
docker logs:
root@panel:/boot# docker logs 6f30c379fc5d
Generating RSA private key, 2048 bit long modulus
e is 65537 (0x10001)
Signature ok
subject=/C=DE/ST=BW/L=Stuttgart/O=Dummy Authority/CN=localhost
Getting CA Private Key
loolforkit version details: 2.0.1 - 2.0.1
office version details: { "ProductName": "Collabora Office", "ProductVersion": "5.1", "ProductExtension": ".1
0.15", "BuildId": "345fa14e85e6e36ad0280f4e549c70f6b9af1a18" }
Signature ok
wsd-00026-0030 0:32:52.769170 [ client_ws_0001 ] ERR  ClientRequestHandler::handleClientRequest: Exception: I
nvalid URI.| wsd/LOOLWSD.cpp:1226
wsd-00026-0031 0:32:59.263053 [ client_ws_0002 ] ERR  ClientRequestHandler::handleClientRequest: Exception: I
wsd-00026-0030 0:33:14.262702 [ client_ws_0003 ] ERR  ClientRequestHandler::handleClientRequest: Exception: I
Just a little question. Is it possible to launch CollaBora without docker?
Docker with a LXC or OVZ Container won’t work correctly or am I wrong?
look here: [HOWTO] Collabora 2.0 without using Docker not for prod
you should have two different host
cloudhost
officehost (docker image)
docker should run with connection to cloudhost not officehost
you are starting the docker image with officehost as full domainname
the connection to officehost will be done with reverse proxy
