i run
sudo -u www-data php /var/www/html/occ circles:test
- GET request on https://nextcloudX/index.php/csrftoken: 301
in private circles i can only add one user. if i add second user , the first user will overwriten.
In nextcloud.log:
user":"ncadmin","app":"no app in ontext","method":"PUT","url":"/apps/circles/v1/circles/9e6e96b8efb96f/member","message":"issue while useClient(): GuzzleHttp\\Exception\\RequestException; cURL error 60: SSL certificate problem: unable to get local issuer certificate (see https://curl.haxx.se/libcurl/c/libcurl-errors.html); 0"
I have try try solution with cert in php.ini - no success
