Can't Remove group assigned to a user with nextcloud 20.0.0
### Steps to repr…oduce
1. Create group in the admin user page
2. assign this group then try to remove it
### Expected behaviour
group must be cleared
### Actual behaviour
group stay attached to the user
### Server configuration
**Operating system:**
Debian 10.6
Docker version 19.03.12
**Web server:** (Official docker container)
Server version: Apache/2.4.38 (Debian)
Server built: 2020-08-25T20:08:29
**Database:** (Official docker container)
Mariadb 10.5.5
**PHP version:**
PHP 7.4.11 (cli) (built: Oct 1 2020 19:35:35) ( NTS )
**Nextcloud version:** (see Nextcloud admin page)
20.0.0
**Updated from an older Nextcloud/ownCloud or fresh install:**
updated from 19.0.3 nextcloud version
**Where did you install Nextcloud from:**
Docker
**Signing status:**
<details>
<summary>Signing status</summary>
No errors have been found.
</details>
**List of activated apps:**
<details>
<summary>App list</summary>
- accessibility: 1.6.0
- activity: 2.13.1
- bruteforcesettings: 2.0.1
- calendar: 2.1.2
- cloud_federation_api: 1.3.0
- comments: 1.10.0
- contactsinteraction: 1.1.0
- dashboard: 7.0.0
- dav: 1.16.0
- deck: 1.1.0
- federatedfilesharing: 1.10.1
- federation: 1.10.1
- files: 1.15.0
- files_external: 1.11.1
- files_markdown: 2.3.1
- files_pdfviewer: 2.0.1
- files_rightclick: 0.17.0
- files_sharing: 1.12.0
- files_trashbin: 1.10.1
- files_versions: 1.13.0
- files_videoplayer: 1.9.0
- firstrunwizard: 2.9.0
- logreader: 2.5.0
- lookup_server_connector: 1.8.0
- mail: 1.5.0
- nextcloud_announcements: 1.9.0
- notes: 4.0.0
- notifications: 2.8.0
- oauth2: 1.8.0
- onlyoffice: 6.0.2
- password_policy: 1.10.1
- photos: 1.2.0
- privacy: 1.4.0
- provisioning_api: 1.10.0
- recommendations: 0.8.0
- riotchat: 0.6.11
- serverinfo: 1.10.0
- settings: 1.2.0
- sharebymail: 1.10.0
- spreed: 10.0.0
- support: 1.3.0
- survey_client: 1.8.0
- systemtags: 1.10.0
- tasks: 0.13.3
- text: 3.1.0
- theming: 1.11.0
- twofactor_backupcodes: 1.9.0
- updatenotification: 1.10.0
- user_status: 1.0.0
- viewer: 1.4.0
- weather_status: 1.0.0
- workflowengine: 2.2.0
- admin_audit
- announcementcenter
- drawio
- encryption
- external
- fulltextsearch
- rainloop
- richdocuments
- user_external
- user_ldap
</details>
**Nextcloud configuration:**
<details>
<summary>Config report</summary>
"htaccess.RewriteBase": "\/",
"apps_paths": [
"url": "\/apps",
"writable": false
"url": "\/custom_apps",
"writable": true
"localhost",
"nextcloud.domain.com"
"dbtype": "mysql",
"version": "20.0.0.9",
"overwrite.cli.url": "https:\/\/nextcloud.domain.com",
"dbport": "",
"mysql.utf8mb4": true,
"onlyoffice": {
"verify_peer_off": true
"loglevel": 0,
"overwriteprotocol": "https",
"theme": "",
"app_install_overwrite": [
"spreed",
"onlyoffice",
"calendar",
"drawio"
"apps": {
"accessibility": {
"enabled": "yes",
"installed_version": "1.6.0",
"types": ""
"activity": {
"enabled": "yes",
"installed_version": "2.13.1",
"types": "filesystem"
"announcementcenter": {
"enabled": "no",
"installed_version": "4.0.0",
"types": "logging"
"backgroundjob": {
"lastjob": "21"
"bruteforcesettings": {
"enabled": "yes",
"installed_version": "2.0.1",
"types": ""
"calendar": {
"enabled": "yes",
"installed_version": "2.1.2",
"types": ""
"cloud_federation_api": {
"enabled": "yes",
"installed_version": "1.3.0",
"comments": {
"enabled": "yes",
"installed_version": "1.10.0",
"types": "logging"
"contactsinteraction": {
"enabled": "yes",
"installed_version": "1.1.0",
"types": "dav"
"core": {
"installed.bundles": "[\"CoreBundle\"]",
"installedat": "1599158953.3778",
"lastcron": "1602013184",
"lastupdateResult": "[]",
"lastupdatedat": "0",
"oc.integritycheck.checker": "[]",
"public_files": "files_sharing\/public.php",
"public_webdav": "dav\/appinfo\/v1\/publicwebdav.php",
"shareapi_only_share_with_group_members": "yes",
"theming.variables": "b92d206521717ac032f8aa58d3c7ff2f",
"vendor": "nextcloud"
"dashboard": {
"enabled": "yes",
"installed_version": "7.0.0",
"types": ""
"dav": {
"buildCalendarReminderIndex": "yes",
"buildCalendarSearchIndex": "yes",
"chunks_migrated": "1",
"enabled": "yes",
"installed_version": "1.16.0",
"regeneratedBirthdayCalendarsForYearFix": "yes",
"deck": {
"enabled": "yes",
"types": "dav"
"drawio": {
"DrawioAutosave": "yes",
"DrawioLang": "auto",
"DrawioOffline": "no",
"DrawioTheme": "kennedy",
"DrawioUrl": "https:\/\/drawio.domain.com",
"DrawioXml": "yes",
"enabled": "no",
"installed_version": "0.9.7",
"external": {
"enabled": "no",
"installed_version": "3.7.0",
"max_site": "2",
"sites": "***REMOVED SENSITIVE VALUE***",
"types": ""
"federatedfilesharing": {
"enabled": "yes",
"installed_version": "1.10.1",
"types": ""
"federation": {
"enabled": "yes",
"types": "authentication"
"files": {
"cronjob_scan_files": "500",
"enabled": "yes",
"installed_version": "1.15.0",
"types": "filesystem",
"watermark_allGroups": "no",
"watermark_allGroupsList": "",
"watermark_allTags": "no",
"watermark_allTagsList": "",
"watermark_enabled": "no",
"watermark_linkAll": "no",
"watermark_linkRead": "no",
"watermark_linkSecure": "no",
"watermark_linkTags": "no",
"watermark_linkTagsList": "",
"watermark_shareAll": "no",
"watermark_shareRead": "no",
"watermark_text": ""
"files_external": {
"enabled": "yes",
"installed_version": "1.11.1",
"files_markdown": {
"enabled": "yes",
"installed_version": "2.3.1",
"types": ""
"files_pdfviewer": {
"enabled": "yes",
"types": ""
"files_rightclick": {
"enabled": "yes",
"installed_version": "0.17.0",
"types": ""
"files_sharing": {
"enabled": "yes",
"installed_version": "1.12.0",
"files_trashbin": {
"enabled": "yes",
"types": "filesystem,dav"
"files_versions": {
"enabled": "yes",
"installed_version": "1.13.0",
"files_videoplayer": {
"enabled": "yes",
"installed_version": "1.9.0",
"types": ""
"firstrunwizard": {
"enabled": "yes",
"installed_version": "2.9.0",
"types": "logging"
"fulltextsearch": {
"enabled": "no",
"installed_version": "1.4.2",
"types": ""
"logreader": {
"enabled": "yes",
"installed_version": "2.5.0",
"levels": "01111",
"types": ""
"lookup_server_connector": {
"enabled": "yes",
"installed_version": "1.8.0",
"mail": {
"enabled": "yes",
"installed_version": "1.5.0",
"types": ""
"nextcloud_announcements": {
"enabled": "yes",
"pub_date": "Thu, 24 Oct 2019 00:00:00 +0200",
"types": "logging"
"notes": {
"enabled": "yes",
"types": ""
"notifications": {
"enabled": "yes",
"installed_version": "2.8.0",
"types": "logging"
"oauth2": {
"enabled": "yes",
"onlyoffice": {
"DocumentServerInternalUrl": "https:\/\/onlyoffice.domain.com\/",
"DocumentServerUrl": "https:\/\/onlyoffice.domain.com\/",
"StorageUrl": "https:\/\/nextcloud.domain.com\/",
"customizationChat": "true",
"customizationCompactHeader": "true",
"customizationFeedback": "true",
"customizationForcesave": "false",
"customizationHelp": "true",
"customizationReviewDisplay": "original",
"customizationToolbarNoTabs": "true",
"defFormats": "{\"csv\":\"true\",\"doc\":\"true\",\"docm\":\"false\",\"docx\":\"true\",\"dotx\":\"false\",\"epub\":\"false\",\"html\":\"false\",\"odp\":\"true\",\"ods\":\"true\",\"odt\":\"true\",\"otp\":\"false\",\"ots\":\"false\",\"ott\":\"false\",\"pdf\":\"false\",\"potm\":\"false\",\"potx\":\"true\",\"ppsm\":\"false\",\"ppsx\":\"false\",\"ppt\":\"true\",\"pptm\":\"false\",\"pptx\":\"true\",\"rtf\":\"false\",\"txt\":\"false\",\"xls\":\"false\",\"xlsm\":\"false\",\"xlsx\":\"true\",\"xltm\":\"false\",\"xltx\":\"false\"}",
"demo": "{\"available\":false,\"enabled\":false,\"start\":{\"date\":\"2020-09-03 19:18:14.655868\",\"timezone_type\":3,\"timezone\":\"UTC\"}}",
"editFormats": "{\"csv\":\"true\",\"odp\":\"false\",\"ods\":\"false\",\"odt\":\"false\",\"rtf\":\"false\",\"txt\":\"true\"}",
"enabled": "yes",
"groups": "[]",
"installed_version": "6.0.2",
"jwt_secret": "",
"sameTab": "false",
"settings_error": "",
"verify_peer_off": "false"
"password_policy": {
"enabled": "yes",
"photos": {
"enabled": "yes",
"installed_version": "1.2.0",
"types": ""
"privacy": {
"enabled": "yes",
"installed_version": "1.4.0",
"types": ""
"provisioning_api": {
"enabled": "yes",
"types": "prevent_group_restriction"
"rainloop": {
"enabled": "no",
"installed_version": "7.0.3",
"types": ""
"recommendations": {
"enabled": "yes",
"installed_version": "0.8.0",
"types": ""
"richdocuments": {
"disable_certificate_verification": "",
"enabled": "no",
"installed_version": "3.7.4",
"public_wopi_url": "https:\/\/collabora.domain.com",
"types": "filesystem,dav,prevent_group_restriction",
"wopi_url": "https:\/\/collabora.domain.com:443"
"riotchat": {
"enabled": "yes",
"installed_version": "0.6.11",
"server_name": "NAS nextcloud",
"types": ""
"serverinfo": {
"enabled": "yes",
"types": ""
"settings": {
"enabled": "yes",
"types": ""
"sharebymail": {
"enabled": "yes",
"spreed": {
"enabled": "yes",
"has_reference_id": "yes",
"installed_version": "10.0.0",
"project_access_invalidated": "1",
"signaling_ticket_secret": "***REMOVED SENSITIVE VALUE***",
"stun_servers": "***REMOVED SENSITIVE VALUE***",
"support": {
"SwitchUpdaterServerHasRun": "yes",
"enabled": "yes",
"types": "session"
"survey_client": {
"enabled": "yes",
"types": ""
"systemtags": {
"enabled": "yes",
"types": "logging"
"tasks": {
"enabled": "yes",
"installed_version": "0.13.3",
"types": ""
"text": {
"enabled": "yes",
"installed_version": "3.1.0",
"types": "dav"
"theming": {
"enabled": "yes",
"installed_version": "1.11.0",
"types": "logging"
"twofactor_backupcodes": {
"enabled": "yes",
"types": ""
"updatenotification": {
"enabled": "yes",
"files_markdown": "2.3.1",
"onlyoffice": "6.0.0",
"riotchat": "0.6.11",
"spreed": "9.0.4",
"types": "",
"update_check_errors": "0"
"user_external": {
"enabled": "no",
"installed_version": "0.10.0",
"types": "prelogin,authentication"
"user_status": {
"enabled": "yes",
"installed_version": "1.0.0",
"types": ""
"viewer": {
"enabled": "yes",
"types": ""
"weather_status": {
"enabled": "yes",
"types": ""
"workflowengine": {
"enabled": "yes",
"installed_version": "2.2.0",
</details>
**Are you using external storage, if yes which one:** local/smb/sftp/...
yes - local
**Are you using encryption:** yes/no
no
**Are you using an external user-backend, if yes which one:** LDAP/ActiveDirectory/Webdav/...
no
### Client configuration
**Browser:**
Brave
Debian
### Logs
</details>
#### Nextcloud log (from interface)
<details>
<summary>Nextcloud log</summary>
[no app in context] Error: Exception: Argument 2 passed to OCA\Provisioning_API\Controller\UsersController::removeFromGroup() must be of the type string, null given, called in /var/www/html/lib/private/AppFramework/Http/Dispatcher.php on line 169 at <<closure>>
0. /var/www/html/lib/private/AppFramework/App.php line 152
OC\AppFramework\Http\Dispatcher->dispatch(OCA\Provisioning ... {}, "removeFromGroup")
1. /var/www/html/lib/private/Route/Router.php line 308
OC\AppFramework\App::main("OCA\\Provisioni ... r", "removeFromGroup", OC\AppFramework\ ... {}, {action: null,us ... "})
2. /var/www/html/ocs/v1.php line 88
OC\Route\Router->match("/ocsapp/cloud/users/test/groups")
3. /var/www/html/ocs/v2.php line 24
require_once("/var/www/html/ocs/v1.php")
DELETE /ocs/v2.php/cloud/users/test/groups
{"reqId":"2lI24o4vqoNnMmAOXpUZ","level":3,"time":"2020-10-06T19:57:09+00:00","remoteAddr":"192.168.1.50","user":"admin","app":"no app in context","method":"DELETE","url":"/ocs/v2.php/cloud/users/test/groups","message":{"Exception":"Exception","Message":"Argument 2 passed to OCA\\Provisioning_API\\Controller\\UsersController::removeFromGroup() must be of the type string, null given, called in /var/www/html/lib/private/AppFramework/Http/Dispatcher.php on line 169","Code":0,"Trace":[{"file":"/var/www/html/lib/private/AppFramework/App.php","line":152,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Provisioning_API\\Controller\\UsersController"},"removeFromGroup"]},{"file":"/var/www/html/lib/private/Route/Router.php","line":308,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Provisioning_API\\Controller\\UsersController","removeFromGroup",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"action":null,"userId":"test","_route":"ocs.provisioning_api.Users.removeFromGroup"}]},{"file":"/var/www/html/ocs/v1.php","line":88,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/ocsapp/cloud/users/test/groups"]},{"file":"/var/www/html/ocs/v2.php","line":24,"args":["/var/www/html/ocs/v1.php"],"function":"require_once"}],"File":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","Line":110,"Previous":{"Exception":"TypeError","Message":"Argument 2 passed to OCA\\Provisioning_API\\Controller\\UsersController::removeFromGroup() must be of the type string, null given, called in /var/www/html/lib/private/AppFramework/Http/Dispatcher.php on line 169","Code":0,"Trace":[{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":169,"function":"removeFromGroup","class":"OCA\\Provisioning_API\\Controller\\UsersController","type":"->","args":["test",null]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":100,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Provisioning_API\\Controller\\UsersController"},"removeFromGroup"]},{"file":"/var/www/html/lib/private/AppFramework/App.php","line":152,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Provisioning_API\\Controller\\UsersController"},"removeFromGroup"]},{"file":"/var/www/html/lib/private/Route/Router.php","line":308,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Provisioning_API\\Controller\\UsersController","removeFromGroup",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"action":null,"userId":"test","_route":"ocs.provisioning_api.Users.removeFromGroup"}]},{"file":"/var/www/html/ocs/v1.php","line":88,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/ocsapp/cloud/users/test/groups"]},{"file":"/var/www/html/ocs/v2.php","line":24,"args":["/var/www/html/ocs/v1.php"],"function":"require_once"}],"File":"/var/www/html/apps/provisioning_api/lib/Controller/UsersController.php","Line":802},"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/85.0.4183.121 Safari/537.36","version":"20.0.0.9","id":"5f7cd0be5a8dc"}
</details>
