Good afternoonn
I’ve install nextcloud on my RaspberryPi with Apache and PHP…
I’ve choose my hard disk on USB like default directory data…
The only problem I met is this last:
Il y a quelques avertissements concernant votre configuration.
La configuration du serveur web ne permet pas d’atteindre “/.well-known/caldav”. Vous trouverez plus d’informations dans la documentation .
La configuration du serveur web ne permet pas d’atteindre “/.well-known/carddav”. Vous trouverez plus d’informations dans la documentation .
(I use it in French)
I need to resolve it to add my calendar on Google Agenda or Outlook …
I’ve try to do this:
nextcloud.occ (it’s an alias of sudo -u www-data php occ ) maintenance:update:htaccess , to have an new htaccess file, but the problem persists…
If you need any other information, please ask me and I will answer the more quickly !
Thank you for your help !
Someone can help me !
I’m waiting …
El_Giorgio:
nextcloud.occ
Have you installed nextcloud-snap ?
No… I’ve make an manual installation, not be snap… the “nextcloud.occ” it’s an alias… (https://www.computerhope.com/unix/ualias.htm ) it’s to make an command more shorter or different…
I see. Just wanted to be sure, because nextcloud-snap comes with an included cli-utility nexrcloud.occ
Are you running Nextcloud in a subfolder (e.g. https://www.example.com/nextcloud ) or in webroot (https://www.example.com )?
I see. Just wanted to be sure, because nextcloud-snap comes with an included cli-utility nexrcloud.occ.
I know, it’s because the first time I’ve use nextcloud, it was by snap (by habit, I’ve keep the command)
Webroot ?
My nextcloud folder is in /var/www/nextcloud but I’ve create an apache file specially for nextcloud …
I’ve just to enter in my browser my DNS without the path !
Here is my Apache file:
Thanks for your help
Apache file for nextcloud
<VirtualHost *:80>
DocumentRoot /var/www/nextcloud
ServerName cloud.doussis.be
</VirtualHost>
Is mod_rewrite enabled?
Your Apache file differs a bit from the one in the official documentation. Can you adjust your apache vhost file for nextcloud according to the documentation: https://docs.nextcloud.com/server/17/admin_manual/installation/source_installation.html#apache-web-server-configuration
Can you post the content of your .htaccess file located at https://cloud.doussis.be ?
The problem has been resolved when I’ve add:
<Directory "/var/www/nextcloud/">
Require all granted
AllowOverride All
Options FollowSymLinks MultiViews
<IfModule mod_dav.c>
Dav off
</IfModule>
</Directory>
Into my apache config files, thanks you Bernie_O for your help
The correct syntax is:
HTTP Standard Apache Config
<VirtualHost *:80>
Require all granted
AllowOverride All
Dav off
</IfModule>
</Directory>
RewriteEngine on
RewriteCond %{SERVER_NAME} =cloud.doussis.be
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
HTTPS Apache Config
<IfModule mod_ssl.c>
<VirtualHost *:443>
Require all granted
AllowOverride All
Dav off
</IfModule>
</Directory>
<IfModule mod_headers.c>
Header always set Strict-Transport-Security "max-age=15552000"
</IfModule>
SSLCertificateFile /etc/letsencrypt/live/cloud.doussis.be/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/cloud.doussis.be/privkey.pem
</VirtualHost>
</IfModule>
