Some days ago I set up a new Linux distribution on my desktop pc (= server) and installed a nextcloud (10.0.1) on it. Installed the calendar and contacts plugin, everything is fine.
But the calendar on my tablet does not synchronize with the server - I don’t even have access to the calendar on the webinterface, if I open it with chrome. I can see the monthly overview, but the calendars don’t load. All the other plugins (contacs, files) are fine.
On my mobile phone everything is perfect: The calendar synchronizes, I can see the calendars in the web interface.
So you tried some app and the web interface?
What app did you use?
It’s an Samsung Galaxy Tab S2 with Android 6.0.1.
In fact the browser causing problems is not chrome, but “Internet” (??? could not find another name for that app, probably a Samsung app, version 4.0.30-1).
The calendar view in chrome is fine.
I added a caldav account (address: …/remote.php/dav/) in the tablet’s settings, it recognizes the cloud server and the four calendars I use.
In the app “Business Calendar” I still can see the four calendars under “Konten”, but only one of them is shown / synchronized. The other three (under them is even “contact birthdays”) don’t show any dates / entries.
I updated the server to version 11.0.0 in the meantime.
On my mobile phone with Android 5.x.y everything is fine…
you can testing the app, to connect with: https://demo.nextcloud.com/
-> 1. open the link -> 2. confirm that you are a human -> 3. login in your own instance for 15 minutes -> Try it with domain:65534 (Port is giving from the instance)
for example:
just input the domain (no subfolders)
and you login
