Problem with app store
Good morning afternoon night. I need help with a problem I have that I haven’t solved for 1 week. I installed Nextcloud 24.0.1 on an Ubuntu 22.04.3 ISO server, everything was going well until I wanted to install new applications and I was surprised that the app store option did not appear. Has anyone had this problem or know how to fix it? Thank you very much in advance for taking the time to read.
Nextcloud 24 is no longer supported:
You should update to at least Nextcloud 26, better 27.1, to be on a version that is supported with all new bugfixes and security patches.
There was a bug in Serverinfo, that resulted in disconnection to the appstore.
You have still the ability to install apps with occ, as long as you do not use the serverinfo tab, since that could provoke an IP-ban by the appstore.
You can browse all available apps on the web interface https://apps.nextcloud.com or, if you prefere the commandline, you can browse the apstore (for your version) with the commandline Appstore “nc-apps
Simply install it with
sudo wget -qO /usr/local/bin/nc-apps https://global-social.net/script/nc-apps
sudo chmod +x /usr/local/bin/nc-apps
Then you can run the cli-appstore with
nc-apps
You can list and update your apps with nc-apps. When you want to install, remove, dis/enable an app, then do it with occ app:*:
 app
  app:disable                            disable an app
  app:enable                             enable an app
  app:install                            install an app
  app:remove                             remove an app
Much luck,
ernolf
