I have downloaded the latest version of Nextcloud for iOS via AppStore but don’t open it I have IOS 13.3 until now no problem but with the latest the app went in crashing so is not possible to open it.
Is possible to solve this problem?
Can you give us more Info? Like any Log or which NC Version.
Did you removed the APP and reinstall it?
I have not removed only updated the version is 2.25.5
It may well be worth deleting the app, reinstalling and trying it again. I just had the same problem with the new 2.25.5 and this process - including reauthorisation into my server - worked for me.
Solved thanks I deleted and installed now running
