example
longer
example
here
Nextcloud version 21.0.1 RC1
Operating system and version Debian 10.9
Apache or nginx version Apache 2.4.38-3+deb10u4
PHP version 7.4
Is this the first time you’ve seen this error? (Y/N):Y
- Upgrade from NC 21.0 to 21.0.1 RC1
- the upgrade itself went fine.
- when I checked the Administration/Overview page of my site, there was a message: The database is missing some indexes. Due to the fact that adding indexes on big tables could take some time they were not added automatically. By running “occ db:add-missing-indices” those missing indexes could be added manually while the instance keeps running.
- When I issued the mentioned command, I got these errors:
Check indices of the share table.
Check indices of the filecache table.
Adding additional path index to the filecache table, this can take some time…In ExceptionConverter.php line 114:
An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1089 Incorrect prefix key; the used key part isn’t a string, the used length is longer than the key part, or the storage engine doesn’t support unique prefix keys
In Exception.php line 26:
In Connection.php line 82:
