hi
i have problems upgrading from 23.0.6 to 24.0.2?
Has anyone else succeeded? I use manual method via commandline to upgrade.
The upgrade goes fine, but then I cannot access my nextcloud instance.
thanks for any pointers
edit
ah I think found problem lol NC24 requires Ubuntu 20.04 and php8, ah well looks like going to stick with NC23
Nc24 should still work with php7.4
hi okay thanks
will need to further investigate as the update goes through fine but problem happens after when accessing nextcloud instance, yet to see a similar problem on forums
so seems when i poweroff my (cloud) server and restart after doing an update, they work fine.
anyone know why this is so?
thanks
