"Support intro"
Nextcloud version (eg, 14.0.3) :
Operating system and version (Debian Webhoster) :
Apache or nginx version (eg, Apache ) :
PHP version (eg, 7.0.33) :
Is this the first time you’ve seen this error? (J) :
The output of your Nextcloud log in Admin > Logging :
is_readable(): open_basedir restriction in effect. File(/proc/meminfo) is not within the allowed path(s): (/var/www/vhosts/chiliboo.com/:/tmp/:/dev/urandom) at /var/www/vhosts/chiliboo.com/cloud.chiliboo.de/nextcloud/apps/serverinfo/lib/SystemStatistics.php#96
https://ha01s015.org-dns.com:8443/smb/web/php-info/id/1193
i have follow problem in my Logfile:
This correct form the Support of the Webhoster:
{WEBSPACEROOT}{/}{:}{TMP}{/}:/dev/urandom
Before this was made, and still now after Logging I get the following error message:
Error checking server setup
Page will be reloaded again.
Update bouton can’t start update.
So how this can be solved?
Regards
fmini
