Hello. I cannot update from 11.0.2 to 11.0.3. System informs of an update. Then after the system is automatically downloading “https://download.nextcloud.com/server/releases/nextcloud-11.0.3.zip”, I get error message,
Check for expected files
The following extra files have been found:
o assets.
Everything stops on the Updater webpage. I have no idea which way to go, what to do next. I clicked on “Retry update”. Nothing else happens.
Thank you.
Hello. Thank you for your response. I imagine, you mean, I should login on my server and delete a directory called “assets” in the Nextcloud directory somewhere.
- Sorry, but I am not sure I could find the correct directory to delete.
- I do not think one should have to do such things at all, since the original installation was successful, and the system operates just fine.
- As next step, I will do some more reading, especially that now, that the error message does not display any longer. Now, after clicking on “Nextcloud 11.0.3 is available… blah, blah…”, I get a new page, https://docs.nextcloud.com/server/11/admin_manual/maintenance/upgrade.html. So, next I will read whatever is described on that page.
Thank you again for your feedback, Bernhard Posselt.
