Having problem updating from 11.0.1. Update process does not even start. Any issues?
Same problem here, from 11.0.2. I tried using occ updater and it says I already have the latest version. Is updater broken?
Did you try to access your cloud under your domain?
In last lane it says: Go back your Nextcloud instance to finish the update
I fixed it editing the config file, and setting the version to 11.0.2 (I had 11.0.2.7, weird). Then I was able to do the next update for 11.0.3. SOLVED!
