example
longer
example
here
Nextcloud version (eg, 18.0.2): 18.0.4
Operating system and version (eg, Ubuntu 20.04): Debian 9
Apache or nginx version (eg, Apache 2.4.25): Apache
PHP version (eg, 7.1): 7.4
From the beginning I only published my Nextcloud with https and forwarded 443 in my router to my NC device. Now I need to publish more things and then found nginx-proxy-manager, https://github.com/jc21/nginx-proxy-manager. I run NC at one Debian device and nginx-proxy-manager at another device. I now forward 443 and 80 to my nginx-proxy-manager device in the router and other things I publish works great. The problem I am facing with this solution is that when trying to login to NC it just hangs and loading. If I refresh the page it jumps to the page after login.
Another case is that when using the new authentication (v2) when signing is at Windows or iOS NC application. You will then be redirected to the web page and need to login and press grant access. In this stage it is not possible to press refresh to get further, the login starts from the beginning.
I think some parameter is missing in my config after I moved from only Apache2 directly to nginx proxy before Apache2.
Error PHP Trying to access array offset on value of type bool at /var/www/nextcloud/apps/files_versions/lib/Storage.php#654
'instanceid' => 'oc8ohlj8p16p',
'passwordsalt' => 'ABC123',
'secret' => 'ABC123',
0 => 'sub.domain.se',
'overwrite.cli.url' => 'http://sub.domain.se',
'version' => '18.0.4.2',
'dbname' => 'mydbname',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud_user',
'dbpassword' => 'ABC123',
'theme' => '',
'loglevel' => 2,
'mail_domain' => 'domain.se',
'mail_from_address' => 'subdomain',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_smtpauth' => 1,
'mail_smtphost' => 'smtp....',
'mail_smtpport' => '465',
'mail_smtpname' => 'mail@domain.se',
'mail_smtppassword' => 'ABC123',
'updater.secret' => 'ABC123',
This is my virtual host config in Apache2:
<VirtualHost *:80>
ServerName sub.domain.se
ServerAdmin mail@domain.se
DocumentRoot /var/www/nextcloud
<Directory />
Options FollowSymLinks
AllowOverride All
</Directory>
<Directory /var/www/nextcloud>
Options Indexes Includes FollowSymLinks MultiViews
#AllowOverride AuthConfig
AllowOverride All
Order allow,deny
allow from all
</Directory>
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
AllowOverride None
Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
Order allow,deny
Allow from all
</Directory>
</VirtualHost>
This is the config I found for nginx in nginx-proxy-manager GUI
"domain_names": [
"sub.domain.se"
"forward_scheme": "http",
"forward_host": "192.168.10.100",
"forward_port": 80,
"caching_enabled": true,
"block_exploits": true,
"allow_websocket_upgrade": true,
"access_list_id": 0,
"ssl_forced": false,
"http2_support": false,
"hsts_enabled": false,
"meta": {
"letsencrypt_email": "mail@domain.se",
"letsencrypt_agree": true,
"nginx_online": true,
"nginx_err": null
"advanced_config": "",
"locations": [],
"hsts_subdomains": false,
"owner_user_id": 1
