Client is on Mac OS. They are able to sync with iCal…but when trying to sync with either Fantastical 2 or BusyCal, they are getting an error code 500.
Error: Request failed with status code 500.
https://cal.admeliorallc.com/remote.php/dav/calendars/xxxxxxxx/personal_shared_by_xxx.xxxxxxxx/
When I check the admin log of our Nextcloud server…it lists an error entry that is literally a mile long…and identified as Fatal webdav
I won’t cut and paste the whole thing unless you think I should (there are some names I’d like to keep out of open forums)…It has a huge number of “?”'s and references a whole lot of owncloud-[wholebunch of numbers and leters].ics"
and it ends with…
File":"/home/caladmeliorallc/public_html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractSQLiteDriver.php",“Line”:85,“User”:“bendiscipio”}
