Nextcloud version: 12.0.4 (nextcloud:12.0.4-apache from the docker hub)
Operating system and version: Debian Stable (using Docker 1.13.1; Debian Stable/sloppy host system)
Apache or nginx version: Nginx reverse proxy at the front, v 1.13.6 (jwilder/nginx-proxy:latest); apache 2.4.10 inside of container
PHP version: 7.1.11
Everything seems to spin up as normal, I can even run OCC commands including maintenance:install, but when I visit the URL in my web browser, I get the following error in my logs, and the page does not load.
nextcloud_1 | [Fri Dec 15 04:45:24.612120 2017] [php7:notice] [pid 47] [client 172.18.0.3:53842] {"reqId":"li9tyAFiEkOufA1by43k","level":3,"time":"2017-12-15T04:45:24+00:00","remoteAddr":"172.18.0.3","user":"--","app":"PHP","method":"GET","url":"\\/settings\\/admin","message":"touch(): Utime failed: Permission denied at \\/var\\/www\\/html\\/lib\\/private\\/Config.php#239","userAgent":"Mozilla\\/5.0 (X11; Linux x86_64; rv:57.0) Gecko\\/20100101 Firefox\\/57.0","version":""}
nextcloud_1 | [Fri Dec 15 04:45:24.612299 2017] [php7:notice] [pid 47] [client 172.18.0.3:53842] {"reqId":"li9tyAFiEkOufA1by43k","level":3,"time":"2017-12-15T04:45:24+00:00","remoteAddr":"172.18.0.3","user":"--","app":"PHP","method":"GET","url":"\\/settings\\/admin","message":"fopen(\\/var\\/www\\/html\\/config\\/config.php): failed to open stream: Permission denied at \\/var\\/www\\/html\\/lib\\/private\\/Config.php#240","userAgent":"Mozilla\\/5.0 (X11; Linux x86_64; rv:57.0) Gecko\\/20100101 Firefox\\/57.0","version":""}
nextcloud_1 | [Fri Dec 15 04:45:24.612425 2017] [php7:notice] [pid 47] [client 172.18.0.3:53842] {"reqId":"li9tyAFiEkOufA1by43k","level":3,"time":"2017-12-15T04:45:24+00:00","remoteAddr":"172.18.0.3","user":"--","app":"PHP","method":"GET","url":"\\/settings\\/admin","message":"chmod(): Operation not permitted at \\/var\\/www\\/html\\/lib\\/private\\/Config.php#243","userAgent":"Mozilla\\/5.0 (X11; Linux x86_64; rv:57.0) Gecko\\/20100101 Firefox\\/57.0","version":""}
nextcloud_1 | [Fri Dec 15 04:45:24.795646 2017] [php7:notice] [pid 47] [client 172.18.0.3:53842] {"reqId":"li9tyAFiEkOufA1by43k","level":3,"time":"2017-12-15T04:45:24+00:00","remoteAddr":"172.18.0.3","user":"--","app":"PHP","method":"GET","url":"\\/settings\\/admin","message":"Doctrine\\\\DBAL\\\\Exception\\\\TableNotFoundException: An exception occurred while executing 'SELECT * FROM \\"oc_appconfig\\"':\\n\\nSQLSTATE[HY000]: General error: 1 no such table: oc_appconfig at \\/var\\/www\\/html\\/3rdparty\\/doctrine\\/dbal\\/lib\\/Doctrine\\/DBAL\\/Driver\\/AbstractSQLiteDriver.php#58","userAgent":"Mozilla\\/5.0 (X11; Linux x86_64; rv:57.0) Gecko\\/20100101 Firefox\\/57.0","version":""}
nextcloud_1 | [Fri Dec 15 04:45:24.795899 2017] [php7:notice] [pid 47] [client 172.18.0.3:53842] {"reqId":"li9tyAFiEkOufA1by43k","level":3,"time":"2017-12-15T04:45:24+00:00","remoteAddr":"172.18.0.3","user":"--","app":"PHP","method":"GET","url":"\\/settings\\/admin","message":"fopen(\\/var\\/www\\/html\\/data\\/nextcloud.log): failed to open stream: Permission denied at \\/var\\/www\\/html\\/lib\\/private\\/Log\\/File.php#132","userAgent":"Mozilla\\/5.0 (X11; Linux x86_64; rv:57.0) Gecko\\/20100101 Firefox\\/57.0","version":""}
It seems as though NC doesn’t have permission to access the ./nextcloud/userdata:/var/www/html volume, but the permissions seem to be correct – www-data:root. I was running 12.0.3 with the same configuration and everything worked fine.
My docker-compose file:
version: "2"
services:
nginx_proxy: # reverse proxy
image: nginx-reverse-proxy
ports:
- "80:80"
- "443:443"
volumes:
- /run/docker.sock:/tmp/docker.sock:ro
- ./revProx/webroot/:/usr/share/nginx/html
- ./revProx/vhost.d:/etc/nginx/vhost.d
- ./revProx/certs:/etc/nginx/certs
letsencrypt_nginx_proxy_companion: # should automatically handle
image: jrcs/letsencrypt-nginx-proxy-companion #letsencrypt config
volumes:
- /run/docker.sock:/var/run/docker.sock:ro
volumes_from:
- nginx_proxy
depends_on: #?
- nginx_proxy
environment:
# ACME_TOS_HASH: cc88d8d9517f490191401e7b54e9ffd12a2b9082ec7a1d4cec6101f9f1647e7b
ACME_CA_URI: https://acme-staging.api.letsencrypt.org/directory
nxt_db:
image: mariadb:10.3.2
restart: always
volumes:
- ./nextcloud/database:/var/lib/mysql
environment:
MYSQL_RANDOM_ROOT_PASSWORD: 'yes'
MYSQL_DATABASE: nextcloud
MYSQL_USER: nextcloud
env_file:
- nextcloud.pw.env
depends_on:
- letsencrypt_nginx_proxy_companion
nextcloud:
image: nextcloud:12.0.4
links:
- nxt_db
depends_on:
- nxt_db
volumes:
- ./nextcloud/userdata:/var/www/html
- ./nextcloud/remote_shares:/home/
restart: always
environment:
VIRTUAL_HOST: cloud.madscientists.co
VIRTUAL_NETWORK: nginx-proxy
DEFAULT_HOST: cloud.madscientists.co
LETSENCRYPT_HOST: cloud.madscientists.co
LETSENCRYPT_EMAIL: sysadmin@tams.tech
collabora:
image: 'collabora/code'
links:
- nextcloud
expose:
- 9980
cap_add:
- MKNOD
environment:
domain: cloud\\.madscientists\\.co
VIRTUAL_HOST: office.madscientists.co
DEFAULT_HOST: office.madscientists.co
VIRTUAL_PORT: 9980
VIRTUAL_PROTO: https
LETSENCRYPT_HOST: office.madscientists.co
drawio:
image: ivonet/draw.io
volumes:
- ./apache_conf:/etc/apache2
environment:
VIRTUAL_HOST: draw.madscientists.co
DEFAULT_HOST: draw.madscientists.co
LETSENCRYPT_HOST: draw.madscientists.co
