Problem: RedisException Address not available
Hello @all,
Since the last update to 28.0.1.1, this error message keeps appearing in the log:
“RedisException Address not available
Error while running background job (class: OC\Core\BackgroundJobs\GenerateMetadataJob, arguments: )”.
Corresponding errors also appear when I try to access files or create new folders ( webdav - RedisException Address not available).
There are also no upcoming appointments displayed on the home screen.
It seems to me that this is a Redis problem. But when I test Redis (redis-cli MONITOR) I get an “OK”.
My Nextcloud runs in Docker on an Ubuntu SRV 22.04.3
Unfortunately I can’t do anything with the error message and contacted Dr. Google couldn’t find anything.
Can someone help me.
Thanks in advance.
It looks like it was my installation and initial setup. After I had the usual apps installed at the beginning, I was able to see and change all files and folders in the “Files” area.
But maybe there will be someone who is deeper into it and who can explain it and point out a solution.
