I have changed the storage of the files to a second unit after installation to the mount point / Nextcloud (second hard disk of the server) and since then it does not load the preview of the files on the activity page, what solution can I give you, thank you very much for your help I leave error capture …
Greetings!
Nextcloud version (eg, 12.0.2): NextCloud 16.0.4.1
Operating system and version (eg, Ubuntu 17.04): Centos7
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.6 (CentOS)
PHP version (eg, 7.1): 7.2.10
[Thu Oct 03 08:18:25.849340 2019] [proxy_fcgi:error] [pid 16661] [client 128.100.0.30:48834] AH01068: Got bogus version 129
[Thu Oct 03 08:18:25.962253 2019] [proxy_fcgi:error] [pid 16690] [client 128.100.0.30:48832] AH01068: Got bogus version 222
[Thu Oct 03 08:23:17.011493 2019] [proxy_fcgi:error] [pid 24236] [client 128.100.0.30:34968] AH01068: Got bogus version 83
[Thu Oct 03 08:23:17.498196 2019] [proxy_fcgi:error] [pid 16689] [client 128.100.0.30:35000] AH01068: Got bogus version 129
[Thu Oct 03 08:23:17.523524 2019] [proxy_fcgi:error] [pid 16661] [client 128.100.0.30:34998] AH01068: Got bogus version 71
[Thu Oct 03 08:23:28.965962 2019] [proxy_fcgi:error] [pid 24061] [client 128.100.0.30:35460] AH01068: Got bogus version 97
[Thu Oct 03 08:23:29.068996 2019] [proxy_fcgi:error] [pid 16687] [client 128.100.0.30:35470] AH01068: Got bogus version 129
[Thu Oct 03 08:23:29.322924 2019] [proxy_fcgi:error] [pid 24061] [client 128.100.0.30:35492] AH01068: Got bogus version 240
[Thu Oct 03 08:23:34.647701 2019] [proxy_fcgi:error] [pid 16689] [client 128.100.0.30:35650] AH01068: Got bogus version 88
[Thu Oct 03 08:23:34.672922 2019] [proxy_fcgi:error] [pid 24061] [client 128.100.0.30:35654] AH01068: Got bogus version 146
[Thu Oct 03 08:23:34.700149 2019] [proxy_fcgi:error] [pid 16687] [client 128.100.0.30:35660] AH01068: Got bogus version 69
[Thu Oct 03 08:24:18.731386 2019] [proxy_fcgi:error] [pid 24236] [client 128.100.0.30:37032] AH01068: Got bogus version 71
[Thu Oct 03 08:24:18.756534 2019] [proxy_fcgi:error] [pid 16690] [client 128.100.0.30:37034] AH01068: Got bogus version 129
[Thu Oct 03 08:24:30.545526 2019] [proxy_fcgi:error] [pid 16689] [client 128.100.0.30:37406] AH01068: Got bogus version 64
[Thu Oct 03 08:24:30.696559 2019] [proxy_fcgi:error] [pid 24061] [client 128.100.0.30:37412] AH01068: Got bogus version 89
[Thu Oct 03 08:51:51.717449 2019] [mpm_prefork:notice] [pid 16660] AH00170: caught SIGWINCH, shutting down gracefully
[Thu Oct 03 08:51:52.930517 2019] [suexec:notice] [pid 32278] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Thu Oct 03 08:51:52.933605 2019] [ssl:warn] [pid 32278] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Thu Oct 03 08:51:52.958175 2019] [lbmethod_heartbeat:notice] [pid 32278] AH02282: No slotmem from mod_heartmonitor
[Thu Oct 03 08:51:52.959764 2019] [ssl:warn] [pid 32278] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Thu Oct 03 08:51:52.976675 2019] [mpm_prefork:notice] [pid 32278] AH00163: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips PHP/5.4.16 configured -- resuming normal operations
[Thu Oct 03 08:51:52.976702 2019] [core:notice] [pid 32278] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Thu Oct 03 09:06:56.171255 2019] [proxy_fcgi:error] [pid 32536] [client 128.100.0.30:37084] AH01068: Got bogus version 129
[Thu Oct 03 09:13:56.651429 2019] [proxy_fcgi:error] [pid 32282] [client 128.100.0.30:60358] AH01068: Got bogus version 64
[Thu Oct 03 09:13:56.819877 2019] [proxy_fcgi:error] [pid 32365] [client 128.100.0.30:60370] AH01068: Got bogus version 100
[Thu Oct 03 09:13:56.878967 2019] [proxy_fcgi:error] [pid 32283] [client 128.100.0.30:60410] AH01068: Got bogus version 75
[Thu Oct 03 09:13:56.908030 2019] [proxy_fcgi:error] [pid 32281] [client 128.100.0.30:60422] AH01068: Got bogus version 89
[Thu Oct 03 09:14:19.611616 2019] [proxy_fcgi:error] [pid 32365] [client 128.100.0.30:33746] AH01068: Got bogus version 64
[Thu Oct 03 09:14:20.189477 2019] [proxy_fcgi:error] [pid 32283] [client 128.100.0.30:33776] AH01068: Got bogus version 129
[Thu Oct 03 09:22:49.869211 2019] [proxy_fcgi:error] [pid 32365] [client 128.100.0.30:34300] AH01068: Got bogus version 105
[Thu Oct 03 09:22:50.092287 2019] [proxy_fcgi:error] [pid 32279] [client 128.100.0.30:34324] AH01068: Got bogus version 97
[Thu Oct 03 09:22:58.451065 2019] [proxy_fcgi:error] [pid 32365] [client 128.100.0.30:34798] AH01068: Got bogus version 97
[Thu Oct 03 09:44:31.626600 2019] [mpm_prefork:notice] [pid 32278] AH00170: caught SIGWINCH, shutting down gracefully
[Thu Oct 03 09:44:32.710599 2019] [suexec:notice] [pid 3932] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Thu Oct 03 09:44:32.712381 2019] [ssl:warn] [pid 3932] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Thu Oct 03 09:44:32.742093 2019] [lbmethod_heartbeat:notice] [pid 3932] AH02282: No slotmem from mod_heartmonitor
[Thu Oct 03 09:44:32.744071 2019] [ssl:warn] [pid 3932] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Thu Oct 03 09:44:32.766083 2019] [mpm_prefork:notice] [pid 3932] AH00163: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips PHP/5.4.16 configured -- resuming normal operations
[Thu Oct 03 09:44:32.766118 2019] [core:notice] [pid 3932] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Thu Oct 03 09:45:00.271598 2019] [mpm_prefork:notice] [pid 3932] AH00170: caught SIGWINCH, shutting down gracefully
[Thu Oct 03 09:45:05.508711 2019] [suexec:notice] [pid 4045] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Thu Oct 03 09:45:05.510710 2019] [ssl:warn] [pid 4045] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Thu Oct 03 09:45:05.540849 2019] [lbmethod_heartbeat:notice] [pid 4045] AH02282: No slotmem from mod_heartmonitor
[Thu Oct 03 09:45:05.542851 2019] [ssl:warn] [pid 4045] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Thu Oct 03 09:45:05.566995 2019] [mpm_prefork:notice] [pid 4045] AH00163: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips PHP/5.4.16 configured -- resuming normal operations
[Thu Oct 03 09:45:05.567030 2019] [core:notice] [pid 4045] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Thu Oct 03 09:45:15.589212 2019] [proxy_fcgi:error] [pid 4046] [client 128.100.0.30:54722] AH01068: Got bogus version 105
[Thu Oct 03 09:47:09.410359 2019] [mpm_prefork:notice] [pid 4045] AH00170: caught SIGWINCH, shutting down gracefully
[Thu Oct 03 09:47:10.483804 2019] [suexec:notice] [pid 4303] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Thu Oct 03 09:47:10.485484 2019] [ssl:warn] [pid 4303] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Thu Oct 03 09:47:10.510662 2019] [lbmethod_heartbeat:notice] [pid 4303] AH02282: No slotmem from mod_heartmonitor
[Thu Oct 03 09:47:10.512315 2019] [ssl:warn] [pid 4303] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Thu Oct 03 09:47:10.529731 2019] [mpm_prefork:notice] [pid 4303] AH00163: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips PHP/5.4.16 configured -- resuming normal operations
[Thu Oct 03 09:47:10.529756 2019] [core:notice] [pid 4303] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
