onlyoffice / documentserver with 80 / tcp forwarding, 0.0.0.0:8443->443/tcp
Changed the “rejectUnauthorized” parameter in the container: false in the file
/etc/onlyoffice/documentserver/default.json
In sudo nano /usr/share/nginx/nextcloud/config/config.php file
Added line ’onlyoffice’ => array (‘verify_peer_off’ => TRUE,),
The container has restarted, but the page is not available at https://192.168.23.2:8443. How is it distributed across web servers? If the request is directed to https://192.168.23.2, then the main Nginx web server should respond, and if the request is directed to https://192.168.23.2:8443, then the web server from docker should respond, but I have a feeling that when When I call the page https://192.168.23.2:8443, the request is sent to the main Nginx web server, how can I check? Is it possible to change some settings of the Nginx server itself?
I tried deploying a docker container with OnlyOffice on a virial machine then everything worked there
