example
longer
example
here
Nextcloud version (eg, 29.0.5): 28.0.11
Operating system and version (eg, Ubuntu 24.04): 20.04
Apache or nginx version (eg, Apache 2.4.25): 2.4.46
PHP version (eg, 8.3): 8.2.24
After upgrade i Get the message:
One or more mimetype migrations are available. Occasionally…
Use the command occ maintenance:repair --include-expensive
to perform the migrations.
When I used that command in Terminal I get the message
Command “maintenance:repair --include-expensive” is not defined.
I read already that there’s a bug, but my problem seems different, because the command don’t work at all
Is this the first time you’ve seen this error? (Y/N):Y
PASTE HERE
PASTE HERE
'instanceid' => 'octwfmkva7ix',
'passwordsalt' => 'l',
'secret' => '',
0 => 'glinithai.ddns.net',
0 =>
'host' => 'localhost',
'port' => 6379,
'memcache.locking' => '\\OC\\Memcache\\APCu',
'datadirectory' => '/srv/dateien/nextcloud/data',
'overwrite.cli.url' => 'https://glinithai.ddns.net/nextcloud',
'version' => '28.0.11.1',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => ',
'logtimezone' => 'UTC',
'mail_from_address' => 'carlo',
'mail_smtpmode' => 'sendmail',
'mail_domain' => 'glini.net',
'mail_smtphost' => 'smtp.glini.net',
'theme' => '',
'defaultapp' => 'spreed',
'loglevel' => 2,
'remember_login_cookie_lifetime' => 1296000,
'data-fingerprint' => 'd56160fd802481e31384c5f12bcd8494',
'mail_smtpport' => '465',
'mail_smtpsecure' => 'ssl',
'has_rebuilt_cache' => true,
'default_phone_region' => 'TH',
'app_install_overwrite' =>
0 => 'apporder',
1 => 'health',
2 => 'podcast',
3 => 'weather',
4 => 'carnet',
5 => 'facerecognition',
6 => 'officeonline',
7 => 'cms_pico',
'encryption.legacy_format_support' => false,
'encryption.key_storage_migrated' => false,
'allow_local_remote_servers' => 'true',
'memories.db.triggers.fcu' => true,
'memories.exiftool' => '/srv/dateien/html/nextcloud/apps/memories/bin-ext/exiftool-amd64-glibc',
'memories.vod.path' => '/srv/dateien/html/nextcloud/apps/memories/bin-ext/go-vod-amd64',
'memories.vod.ffmpeg' => '/usr/local/bin/ffmpeg',
'memories.vod.ffprobe' => '/usr/local/bin/ffprobe',
'memories.gis_type' => 1,
'enabledPreviewProviders' =>
0 => 'OC\\Preview\\Image',
1 => 'OC\\Preview\\HEIC',
2 => 'OC\\Preview\\TIFF',
3 => 'OC\\Preview\\Movie',
'preview_max_memory' => 1024,
'memories.vod.disable' => false,
'memories.vod.vaapi' => true,
'updater.secret' => '$2y$10$89X1ZbEqUIrHGJlAPJOOv.EFUKU4AZqPB3eoiPC5zQhCjb8tbWTra',
The output of your Apache/nginx/system log in `/var/log/____`:
PASTE HERE
PASTE HERE
