"Problem loading page, reloading in 5 seconds"
I try to install nexcloud 10, but I’ve got this message ā€œProblem loading page, reloading in 5 secondsā€, and the page reload every 5 seconds.
I tried with owncloud, and I’ve got the same problem.
I try to install nexcloud with the 2 methods : archive file on my server and web installer, and it’s the same problem.
Could someone help me please ?
Thanks !
Try applying https://github.com/nextcloud/server/pull/984/files manually
I’m getting the same error how do I go about fixing it
The mentioned patch is in the current version 10.0.1, do you use this version?
I’m getting the same error on 10.0.1
If I disable the share function app, the error is gone.
Then open a new bug report on https://github.com/nextcloud/server/issues and give more details about your environment and how to reproduce this error.
This didn’t work for me.
Could you explain how do you do that ?
I have the the same problem and https://github.com/nextcloud/server/pull/984/files doesn’t solve it
I have tested to disable ā€œcollabraā€ and ā€œguestsā€ with no effect.
The reload appears, when I try to sort the filelist by a column
It also is in userlist since I have more then x users added …
Any suggestons?
Yes, start your own topic and provide as much information about your current environment as possible. There’s a handy template you can follow.
Where is the template?
Create a new topic and you’ll see it
It’s a little bit late to help Lisalisa, but if somebody else discovers this problem:
I just had a similar error and got it solved by changing the background picture of the logon screen (please don’t ask why! :slight_smile: )!
