example
longer
example
here
Nextcloud version (eg, 18.0.2):
Operating system and version Ubuntu 20.04):
PHP version 7.3
- install nextcloud using apache2 and php 7.3
- load up nextcloud on local ip
Logging won't load
Config.Php contents
'instanceid' => 'oclvrov2icmm',
'passwordsalt' => 'xxxx',
'secret' => 'xxxx',
0 => '192.168.0.59',
'datadirectory' => '/md0/Nextcloud',
'version' => '20.0.2.2',
'overwrite.cli.url' => 'http://192.168.0.59',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextclouduser',
'dbpassword' => 'xxxx',
Not using nginx just ip
