example
longer
example
here
Nextcloud version : 23.0.2
Operating system and version : client on mac ox 10.15.7
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 7.4): 7.3 > OVH.com
- I create a new text file and register it in a share : OK
- I open this texte file, modifie and save it in the share : Impossible to sync ; the distant server replies “400 Bad request”. There is a red tag on the file in the client.
PASTE HERE
PASTE HERE
