Dear colleagues,
I have the following configuration:
versions
CentOS Linux release 7.3.1611
Apache/2.4.6 (CentOS)
Nextcloud Rel: 12.0.4
selinux
SELINUX=disabled
SELINUXTYPE=targeted
I currently have extracted nextcloud in path1:/var/www/tld/domain/nextcloud/01/
due to disk space constraints I need to put the data files in home directory of user nextcoud i.e. in path2:/home/nextcloud/01/data/
the httpd user is apache
I have changed the owner of both path1, path2 and subdirectories to apache:apache with permissions set to 755
having created the mysql database and associated user
I am starting up the web installer supplying a data path as path2: and I get an error in the form of :
“Can’t create or write into the data directory /home/nextcloud/01/data”
sudo -u apache ls -al /home/nextcloud/01
gives
ls: cannot access /home/nextcloud/01: Permission denied
Can anybody offer any ideas of what might be the cause of the error since the permissions appear to be correct.
