Hello, I am new to Nextcloud and installed Nextcloudpi on my Raspberry PI 4 today. I have the problem, that the Appstore is responding to slow, because of the poor server performance of nextcloud. Instead of showing a error message it just gives me a blank Site. The fix to this is to edit some code in some config file. Where can I find those files? I am only unsing the panel of NextcloudPi and there are many configurations that I can do there but I didn´t find the right one. How can I access those config files? Do I need to put the Micro-SD in my computer and use a special program or do i need to do something on the Raspberry?
usually you access shell over ssh you can then goto your installation location mostly /var/www/nextcloud then there’s a folder config with the file config.php where the Nextcloud settings are.
you can also search in the shell for folders or files with the find command.
find / -type f -name config.php
I feeling like this is a very dumb question, but how can I connect this SSH thing? Can you send me a YouTube Video or something? Im just really new with doing this stuff.
I don’t own a RPI so I’m not that familiar with it I thought is was enabled by default but looking at these videos it seems you need to create a file on the SDcard.
Check these out and come back with any questions
first find https://www.youtube.com/watch?v=63yw7b0NuWc
2nd one with 4 ways to enable SSH https://www.youtube.com/watch?v=HU6Wk0hkpVQ
I don’t use Windows any more but a good program that I used back in the days when I did is called putty.exe ( https://www.puttygen.com/download-putty ) it’s a single file that gives you many options including SSH’ing. If you use mac or Linux you can install SSH with the software manager.
I got the ssh working with a few other Videos but if i run the command “find / -type f -name config.php” or “/var/www/nextcloud/config.php” it says “Permission denied”. And that Problem is with any file i try to access.
