example
longer
example
here
Nextcloud version: 18.0.4
Operating system and version: Debian 10 Linux xxx 4.19.0-6-amd64 #1 SMP Debian 4.19.67-2+deb10u2 (2019-11-11) x86_64 GNU/Linux
Apache or nginx version: Server version: Apache/2.4.43 (Debian)
PHP version: PHP 7.3.18-1+0~20200514.58+debian10~1.gbp12fa4f
When sharing a folder to an federated group which is provided by the remote ldap, I retrieve the error: InvalidArgumentException: Invalid Federated Cloud ID
Sharing the same folder to the same instance but to an “internal” nextcloud group works fine.
Is this the first time you’ve seen this error? Yes
- Install Nextcloud, Create a folder
- Have a remote Instance (with ldap groups) you don’t control and you want to share with.
- Enable group federative share on both sides (or just the retrieving side ?)
- Share your folder with
ldap-group@cloud.remote-instance.org
orldap-group@https://cloud.remote-instance.org
and retrieve the error - (Optional) Share your folder with (nextcloud group)
admin@cloud.remote-instance.org
oradmin@https://cloud.remote-instance.org
and retrieve a success
[no app in context] Error: InvalidArgumentException: Invalid Federated Cloud ID at <<closure>>
0. /var/www/owncloud/lib/private/Collaboration/Collaborators/RemoteGroupPlugin.php line 61
OC\Collaboration\Collaborators\RemoteGroupPlugin->splitGroupRemote("reffi@")
1. /var/www/owncloud/lib/private/Collaboration/Collaborators/Search.php line 65
OC\Collaboration\Collaborators\RemoteGroupPlugin->search("reffi@", 200, 0, OC\Collaboration ... {})
2. /var/www/owncloud/apps/files_sharing/lib/Controller/ShareesAPIController.php line 221
OC\Collaboration\Collaborators\Search->search("ldap-group@", [0,1,4,6,9], false, 200, 0)
3. /var/www/owncloud/lib/private/AppFramework/Http/Dispatcher.php line 170
OCA\Files_Sharing\Controller\ShareesAPIController->search("ldap-group@", "folder", 1, 200, ["0","1","6","9","7","10","8","4"], false)
4. /var/www/owncloud/lib/private/AppFramework/Http/Dispatcher.php line 99
OC\AppFramework\Http\Dispatcher->executeController(OCA\Files_Sharin ... {}, "search")
5. /var/www/owncloud/lib/private/AppFramework/App.php line 125
OC\AppFramework\Http\Dispatcher->dispatch(OCA\Files_Sharin ... {}, "search")
6. /var/www/owncloud/lib/private/AppFramework/Routing/RouteActionHandler.php line 47
OC\AppFramework\App::main("OCA\\Files_Shar ... r", "search", OC\AppFramework\ ... {}, {_route: "ocs.fi ... "})
7. <<closure>>
OC\AppFramework\Routing\RouteActionHandler->__invoke({_route: "ocs.fi ... "})
8. /var/www/owncloud/lib/private/Route/Router.php line 299
call_user_func(OC\AppFramework\ ... {}, {_route: "ocs.fi ... "})
9. /var/www/owncloud/ocs/v1.php line 82
OC\Route\Router->match("/ocsapp/apps/fi ... s")
GET /ocs/v1.php/apps/files_sharing/api/v1/sharees?format=json&itemType=folder&search=reffi@&lookup=false&perPage=200&shareType[]=0&shareType[]=1&shareType[]=6&shareType[]=9&shareType[]=7&shareType[]=10&shareType[]=8&shareType[]=4
from xx.xx.xx.240 by xxx at 2020-05-27T08:46:45+00:00
"dbtype": "mysql",
"version": "18.0.4.2",
"forcessl": true,
"ldapIgnoreNamingRules": false,
"theme": "",
"cloud.xxx.xx",
"xxx.xx-xxx.xx",
"cloudpad.xx.xxx"
"mail_smtpmode": "sendmail",
"loglevel": 0,
"trashbin_retention_obligation": "auto",
"overwrite.cli.url": "https:\/\/cloud.xxx.xxx",
"app_install_overwrite": [
"calendar",
"ownpad",
"user_pwauth",
"documents"
"mysql.utf8mb4": true
"apps": {
"accessibility": {
"enabled": "yes",
"installed_version": "1.4.0",
"types": ""
"activity": {
"enable_email": "no",
"enabled": "yes",
"installed_version": "2.11.0",
"types": "filesystem"
"admin_audit": {
"enabled": "yes",
"installed_version": "1.8.0",
"types": "logging"
"backgroundjob": {
"lastjob": "1433"
"bookmarks": {
"enabled": "no",
"installed_version": "2.3.4",
"types": ""
"bruteForce": {
"whitelist_1": "xxx.xxxx.0.0\/24",
"whitelist_2": "xxx.xxxx.1.0\/24"
"bruteforcesettings": {
"enabled": "yes",
"installed_version": "1.6.0",
"types": ""
"calendar": {
"enabled": "yes",
"installed_version": "2.0.3",
"types": ""
"cloud_federation_api": {
"enabled": "yes",
"installed_version": "1.1.0",
"comments": {
"enabled": "yes",
"types": "logging"
"contacts": {
"enabled": "no",
"installed_version": "3.3.0",
"types": ""
"core": {
"backgroundjobs_mode": "cron",
"default_encryption_module": "OC_DEFAULT_MODULE",
"encryption_enabled": "yes",
"enterpriseLogoChecked": "yes",
"global_cache_gc_lastrun": "1436795148",
"installed.bundles": "[\"CoreBundle\"]",
"installedat": "1389104474.6485",
"lastcron": "1590569533",
"lastupdateResult": "[]",
"lastupdatedat": "1590567612",
"moveavatarsdone": "yes",
"oc.integritycheck.checker": "[]",
"previewsCleanedUp": "1",
"public_caldav": "calendar\/share.php",
"public_calendar": "calendar\/share.php",
"public_documents": "documents\/public.php",
"public_files": "files_sharing\/public.php",
"public_gallery": "gallery\/public.php",
"public_webdav": "dav\/appinfo\/v1\/publicwebdav.php",
"remote_caldav": "dav\/appinfo\/v1\/caldav.php",
"remote_calendar": "dav\/appinfo\/v1\/caldav.php",
"remote_carddav": "dav\/appinfo\/v1\/carddav.php",
"remote_contacts": "dav\/appinfo\/v1\/carddav.php",
"remote_core.css": "\/core\/minimizer.php",
"remote_core.js": "\/core\/minimizer.php",
"remote_dav": "dav\/appinfo\/v2\/remote.php",
"remote_files": "dav\/appinfo\/v1\/webdav.php",
"remote_filesync": "files\/appinfo\/filesync.php",
"remote_webdav": "dav\/appinfo\/v1\/webdav.php",
"repairlegacystoragesdone": "yes",
"scss.variables": "35a20dc699bda08b826f180197856b39",
"shareapi_allow_share_dialog_user_enumeration": "no",
"shareapi_default_expire_date": "yes",
"theming.variables": "ee69444d3d1a73753ae4340410876f7e",
"updater.secret.created": "1588004644",
"vendor": "nextcloud"
"dav": {
"buildCalendarReminderIndex": "yes",
"buildCalendarSearchIndex": "yes",
"chunks_migrated": "1",
"enabled": "yes",
"installed_version": "1.14.0",
"regeneratedBirthdayCalendarsForYearFix": "yes",
"documents": {
"converter": "local",
"enabled": "no",
"installed_version": "0.16.0",
"types": "",
"unstable": "false"
"encryption": {
"enabled": "yes",
"installed_version": "2.6.0",
"masterKeyId": "master_312ea844",
"publicShareKeyId": "pubShare_9fd5400f",
"recoveryAdminEnabled": "1",
"recoveryKeyId": "recovery_454d6396",
"types": "filesystem",
"useMasterKey": "0"
"federatedfilesharing": {
"enabled": "yes",
"types": ""
"federation": {
"autoAddServers": "0",
"enabled": "yes",
"types": "authentication"
"files": {
"backgroundwatcher_previous_file": "1275",
"backgroundwatcher_previous_folder": "575",
"cronjob_scan_files": "500",
"default_quota": "10 GB",
"enabled": "yes",
"installed_version": "1.13.1",
"files_locking": {
"enabled": "no",
"installed_version": "",
"files_pdfviewer": {
"enabled": "no",
"installed_version": "1.7.0",
"types": ""
"files_rightclick": {
"enabled": "yes",
"installed_version": "0.15.2",
"types": ""
"files_sharing": {
"enabled": "yes",
"incoming_server2server_group_share_enabled": "yes",
"installed_version": "1.10.1",
"outgoing_server2server_group_share_enabled": "yes",
"files_texteditor": {
"enabled": "no",
"installed_version": "2.8.0",
"types": ""
"files_trashbin": {
"enabled": "yes",
"types": "filesystem,dav"
"files_versions": {
"enabled": "yes",
"installed_version": "1.11.0",
"files_videoplayer": {
"enabled": "yes",
"types": ""
"files_videoviewer": {
"enabled": "no",
"installed_version": "0.1.3",
"ocsid": "166054",
"types": ""
"firstrunwizard": {
"enabled": "yes",
"installed_version": "2.7.0",
"types": "logging"
"gallery": {
"enabled": "no",
"installed_version": "18.4.0",
"types": ""
"logreader": {
"enabled": "yes",
"installed_version": "2.3.0",
"levels": "01111",
"types": ""
"lookup_server_connector": {
"enabled": "yes",
"metadata": {
"enabled": "yes",
"installed_version": "0.11.1",
"types": ""
"nextcloud_announcements": {
"enabled": "no",
"pub_date": "Thu, 24 Oct 2019 00:00:00 +0200",
"types": "logging"
"notifications": {
"enabled": "yes",
"types": "logging"
"oauth2": {
"enabled": "yes",
"onlyoffice": {
"DocumentServerInternalUrl": "",
"DocumentServerUrl": "https:\/\/collabora.xx.xxx\/",
"StorageUrl": "",
"defFormats": "{\"docx\":\"true\",\"xlsx\":\"true\",\"pptx\":\"true\",\"ppsx\":\"true\",\"txt\":\"false\",\"csv\":\"false\"}",
"enabled": "no",
"installed_version": "4.1.1",
"jwt_secret": "",
"sameTab": "false",
"settings_error": "Bad Request oder Timeout Fehlermeldung",
"skey": "1521837389370",
"ownpad": {
"enabled": "yes",
"installed_version": "0.6.14",
"ownpad_ethercalc_enable": "yes",
"ownpad_ethercalc_host": "https:\/\/calc.xxx.xxx",
"ownpad_etherpad_apikey": "dc406b2ca3237109cf20eba813560264e27134b5ad80e44a7dc63e61f3617f70",
"ownpad_etherpad_cookie_domain": "xxx.xxx",
"ownpad_etherpad_enable": "yes",
"ownpad_etherpad_host": "https:\/\/xxx.xxx.xxxn\/",
"ownpad_etherpad_public_enable": "no",
"ownpad_etherpad_useapi": "yes",
"types": ""
"ownpad_lite": {
"enabled": "no",
"installed_version": "0.2",
"types": ""
"password_policy": {
"enabled": "yes",
"enforceHaveIBeenPwned": "0",
"types": ""
"photos": {
"enabled": "no",
"installed_version": "1.0.0",
"types": ""
"privacy": {
"enabled": "yes",
"installed_version": "1.2.0",
"types": ""
"provisioning_api": {
"enabled": "yes",
"types": "prevent_group_restriction"
"recommendations": {
"enabled": "yes",
"installed_version": "0.6.0",
"types": ""
"richdocuments": {
"disable_certificate_verification": "",
"enabled": "yes",
"installed_version": "3.5.0",
"types": "filesystem,dav,prevent_group_restriction",
"wopi_url": "https:\/\/collabora.xxx.xxx"
"search_lucene": {
"enabled": "no",
"installed_version": "0",
"ocsid": "168709",
"serverinfo": {
"enabled": "yes",
"types": ""
"settings": {
"enabled": "yes",
"types": ""
"sharebymail": {
"enabled": "yes",
"support": {
"enabled": "no",
"types": "session"
"survey_client": {
"apps": "no",
"database": "no",
"enabled": "no",
"encryption": "no",
"files_sharing": "no",
"installed_version": "1.5.0",
"php": "no",
"server": "no",
"stats": "no",
"types": ""
"systemtags": {
"enabled": "yes",
"types": "logging"
"tasks": {
"enabled": "yes",
"installed_version": "0.12.2",
"types": ""
"tasks_enhanced": {
"enabled": "no",
"installed_version": "0.4.1",
"types": ""
"templateeditor": {
"enabled": "no",
"types": ""
"text": {
"enabled": "yes",
"installed_version": "2.0.0",
"types": "dav"
"theming": {
"backgroundMime": "image\/png",
"cachebuster": "13",
"color": "#AF0000",
"enabled": "yes",
"faviconMime": "image\/png",
"installed_version": "1.9.0",
"logoMime": "image\/png",
"name": "XXX Cloud",
"slogan": "***REMOVED SENSITIVE VALUE***",
"types": "logging",
"url": "***REMOVED SENSITIVE VALUE***"
"twofactor_backupcodes": {
"enabled": "yes",
"types": ""
"updatenotification": {
"bookmarks": "2.3.4",
"bruteforcesettings": "1.6.0",
"calendar": "2.0.3",
"core": "18.0.4.2",
"enabled": "[\"admin\"]",
"files_pdfviewer": "1.2.1",
"files_rightclick": "0.15.1",
"metadata": "0.10.0",
"onlyoffice": "4.1.1",
"richdocuments": "3.6.0",
"tasks": "0.13.1",
"theming": "1.4.5",
"types": "",
"update_check_errors": "0",
"user_pwauth": "2.6.4"
"updater": {
"enabled": "no",
"installed_version": "0.6",
"types": ""
"user_external": {
"enabled": "no",
"installed_version": "0.4",
"ocsid": "166060",
"types": "authentication,prelogin"
"user_ldap": {
"enabled": "no",
"installed_version": "0.4.3",
"ocsid": "166061",
"user_pwauth": {
"enabled": "yes",
"installed_version": "2.6.4",
"pwauth_path": "\/usr\/sbin\/pwauth",
"types": "authentication",
"uid_list": "1000-2000"
"user_webdavauth": {
"enabled": "no",
"viewer": {
"enabled": "yes",
"types": ""
"workflowengine": {
"enabled": "yes",
Apache2. No Error log.
cloud.xxx.xxx:443 xx.xx.xx.240 - - [27/May/2020:10:55:57 +0200] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 200 4979 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:76.0) Gecko/20100101 Firefox/76.0"
cloud.xxx.xxx:443 xx.xx.xx.240 - - [27/May/2020:10:55:45 +0200] "GET /index.php/apps/logreader/poll?lastReqId=8QZUluyqdMC6auIJ1XL6 HTTP/1.1" 200 1298 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:76.0) Gecko/20100101 Firefox/76.0"
cloud.xxx.xxx:443 xx.xx.xx.240 - - [27/May/2020:10:55:58 +0200] "POST /ocs/v2.php/apps/files_sharing/api/v1/shares HTTP/1.1" 403 1098 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:76.0) Gecko/20100101 Firefox/76.0"
