When I try to download a file with the “Download As” function it shows the error of the attached image.
What could be happening?
example
longer
example
here
Nextcloud version (eg, 20.0.5): replace me
Operating system and version (eg, Ubuntu 20.04): replace me
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 7.4): replace me
PASTE HERE
PASTE HERE
PASTE HERE
PASTE HERE
PASTE HERE
