[/details]
Im using Nextcloud in Docker with the latest image so: nextcloud:latest
Im using an nginx reverse proxy
The host is a fedora 31 host
I cant login to the Nextcloud Desktop client, specifically the authentication,
every time i try to connect, it opens my browser (as expected), then it asks me to log in,
when i click it i get a button to grant access (didnt ask for me login details), if i click this nothing happens, no matter how long i keep it running.
After a bit i noticed that the link i need to open (http://nextcloud.domain.com/login/v2/flow/BTqyWDLBrb54GrYotU9i6D2o1z2axrm8r9xOWmKUXxR51zEDgtKAaEXvhkj2vK0KLdRcytT4TbbmTHflVZJUNdWL8wcFOsO8IjbSlQJ8K9659ZXbEWu1GcJGPY2a6YlI) redirects to just https://nextcloud.domain.com/login/v2/flow
no clue if this is how its supposed to work but yeah
No logs
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'instanceid' => 'ocqfu63zbiua',
'passwordsalt' => 'redacted',
'secret' => 'redacted',
0 => 'nextcloud.domain.com',
'dbtype' => 'sqlite3',
'version' => '18.0.3.0',
'overwrite.cli.url' => 'http://nextcloud.domain.com',
'twofactor_enforced' => 'false',
'mail_domain' => 'redacted',
'mail_smtpmode' => 'smtp',
'mail_smtphost' => 'protonmail-bridge',
'mail_smtpauth' => 1,
'mail_smtpname' => 'redacted',
'mail_smtppassword' => 'redacted',
'ldapIgnoreNamingRules' => false,
'mail_smtpport' => '25',
The above is the default config.php created by docker
192.168.2.175 - - [17/Apr/2020:23:01:38 +0000] "GET /login/v2/flow/Vgv1FjVSMFVANbvZGtjPwYRBRGgvlvjTq3Wf6pWgxRbXdBf3o9pjd6MvB4rSMfJS7RRsu0SfAHkdW18SxEHMB8KC7Zizl5KUVq9PudUJUZJyFaYIn09iOMmhhAAHtwHf HTTP/1.1" 301 169 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:75.0) Gecko/20100101 Firefox/75.0" "-",
192.168.2.175 - - [17/Apr/2020:23:01:38 +0000] "GET /login/v2/flow HTTP/1.1" 301 169 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:75.0) Gecko/20100101 Firefox/75.0" "-",
192.168.2.175 - - [17/Apr/2020:23:01:38 +0000] "POST /login/v2/poll HTTP/1.1" 301 169 "-" "Mozilla/5.0 (Linux) mirall/2.6.4git (Nextcloud)" "-",
192.168.2.175 - - [17/Apr/2020:23:01:39 +0000] "POST /login/v2/poll HTTP/1.1" 301 169 "-" "Mozilla/5.0 (Linux) mirall/2.6.4git (Nextcloud)" "-",
192.168.2.175 - - [17/Apr/2020:23:01:40 +0000] "GET /login/v2/grant?stateToken=DV8Cj1uncfqBfLK8qmEKjg7cfkxNpyzOeh4MySfieaTvx5HbKSq9l0sCBOfDC649 HTTP/1.1" 301 169 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:75.0) Gecko/20100101 Firefox/75.0" "-",
192.168.2.175 - - [17/Apr/2020:23:02:09 +0000] "POST /login/v2/poll HTTP/1.1" 301 169 "-" "Mozilla/5.0 (Linux) mirall/2.6.4git (Nextcloud)" "-"
If i missed something pls tell me
